injen cold air intake
Old Oct 25, 2005 | 12:48 AM
jcarlson9's Avatar
my "service engine soon" light is on,after i installed the cold air,is this normal ?
Old Oct 25, 2005 | 02:00 PM
njsfastestg's Avatar
G SQUAD
no, it s not. hope you didn t damage the m.a.s. that is 700.00 bucks in it s own. i know mine went last month but luckilly i m cool with the manager and he replaced it under warranty.
Old Oct 25, 2005 | 06:10 PM
leeoaks's Avatar
Florida G35 Club Premier Member
double check to make sure that the maf sensor was put back the same direction that it came out... someone correct me if i am wrong, but i believe that the maf sensor is directional. could solve your problem... good luck
Old Oct 25, 2005 | 06:21 PM
anish3232's Avatar
Yea its normal just do a ECU reset and the MAF has an arrow for the air flow
Old Oct 25, 2005 | 10:13 PM
G SQUAD
due it s not normal for the light to come on. make sure its facing the right way and also make sure that the plug is in all the way. good luck
Old Oct 25, 2005 | 10:42 PM
anish3232's Avatar
My check engine light came on after I installed the Injen Intake do a search its common after you install something that affects the Air Intake its thinking its getting too much air. Just serach for ECU reset you can take it to AutoZone and they check codes for you. Im like 80% sure its becuase you just installed the intake needs an ECU reset
Old Oct 25, 2005 | 10:59 PM
anish3232's Avatar
Exclamation
Heres the link to ECU RESET
Heres another member that had the same problem after he installed his AEM intake.
Heres another member with an Injen Intake with the same problem.
Old Oct 26, 2005 | 12:36 AM
Triple8Sol's Avatar
Mine came on as well, after my Injen install. I was lazy and didn't get a chance to search for those ECU reset instructions. It went away by itself w/o me noticing...prob w/in a week or so?
Old Oct 26, 2005 | 08:27 AM
G35_TX's Avatar
The Injen also causes problems with the car. It mostly seems to cause the car to die if you push in the clutch rolling to a stop.
Old Oct 26, 2005 | 10:31 PM
G SQUAD
i have mine on for 2 1/2 years and no s.e.s light. i guess i m lucky. good ;uck though
Old Oct 26, 2005 | 10:34 PM
JDM 350GT's Avatar
not that safe...if you have injen CAI.
on the good side...its good
but IMO its bit risky...
G35Rican
Jul 31, 2024 01:37 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JLee301
Sep 25, 2015 08:46 PM
dorkstar
Engine - Exhaust
Sep 9, 2015 07:43 PM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
