Plenum on '05 G35?
Old Oct 27, 2005 | 11:47 AM
Teeter's Avatar
Plenum on '05 G35?
I'm doing some research on the potential benefits of either plenum replacement or using a plenum spacer on my '05 Sedan. But I've noticed a couple of comments saying that the '05's already have a redesigned plenum and, therefore, won't see any benefits from a Crawford, Motordyne, etc.
Is this true?
-T
Old Oct 27, 2005 | 11:50 AM
TonyZ_G's Avatar
i would like to know this also.. thanks
Old Oct 27, 2005 | 12:11 PM
jnkirk1974's Avatar
Fastest G35 In Rockwall
Is this true?
-T
Only the '05 Coupes with manual transmissions have the new plenum. The '05 with the Automatic transmission has the old plenum design.
Hope this helps.
Jeff
Old Oct 27, 2005 | 02:31 PM
brasil's Avatar
Hope this helps.
Jeff
I thought that the 05 sedan 6mt had the same exact engine as the 05 coupe 6 mt?
Old Oct 27, 2005 | 02:40 PM
FLFIRE's Avatar
The 298 HP engines are the ones with the redesigned lower plenum. I believe the 05 sedan does have the 298. None of the plenum or spacer mods have been shown to work on the 298 engine.
-FLFire
Charter Member
Florida G35 Club
2005 G35C 5AT DG/Graphite/Sport/50% Huper/Clear Corners/3M Clear Bra
Drivers Side Battery Cover/Samco Intake Tube/Samco Coolant Hoses
Crawford Plenum/K&N Filter/Nismo Headers
Nismo Oil-Radiator Caps/10 Wire GroundingGear/Terk XMicro
Old Oct 27, 2005 | 02:51 PM
trey.hutcheson's Avatar
Correct. Both the coupe AND the sedan 6MT's have the redesigned plenums.
Old Oct 27, 2005 | 04:46 PM
GT-Ron's Avatar
Just wait until the Motordyne MREV mod debuts. That'll be the equivalent (or better) that you're looking for. It's exclusively designed for the '05+ 298HP "RevUp" engine package.
Old Oct 27, 2005 | 05:22 PM
jnkirk1974's Avatar
They do.
Old Oct 28, 2005 | 09:43 PM
ZXiMan's Avatar
That couldn't be further from the truth...
I have a Crawford plenum, and it increased power very nicely, especially above 5000 rpm. With just Crawford plenum, Crawford headers, Crawford hi-flow cats, knife edged throttle body, some port clean up on the lower plenum, UR crank pully and 5 gallons of VP 101 unleaded, I pulled 285hp & 266pft at the wheels on my '05 6MT sedan (the 298hp motor). The only mod that I have tried that I absolutely didn't like was the UT-R Y-pipe which made my car run lean until 6300 rpm (and I lost 23hp & 22pft of torque peak). That's a huge power loss, especially the torque numbers. However, some of that loss was because during the Y-pipe test, I didn't have any race fuel and we could hear some detonation. Stock Y-pipe went back on! Power is back.... heh.
Old Oct 29, 2005 | 04:22 AM
mrjonang's Avatar
you should check the tread about the new plenum from motordyne for the new 05s "revup engine"
Old Oct 29, 2005 | 04:33 AM
EricIsKlumzyee's Avatar
try doing a before and after dyno with your OEM upper plenum thent he crawford plenum..
Old Oct 31, 2005 | 01:48 AM
GTT's Avatar
GTT
G35 Twin Turbo
i was going to buy one for my 05 6mt. so u guys mean it won't do anything. here is the link.
http://store.yahoo.com/sgpracing-store/crcauppl35.html
Old Oct 31, 2005 | 02:01 AM
Andy2434's Avatar
For those of you, whom have a '05 to '06 - 6MT, wait for Motordyne's new M-REV mod. I have the said mod installed and it truly taps in to our G's NA potential.
Here's the link to my review of the soon to be released M-REV mod . . .
https://g35driver.com/forums/reviews/73093-motordyne-mrev-mod.html
Old Nov 1, 2005 | 03:59 PM
425skyline's Avatar
but..
-FLFire
Charter Member
Florida G35 Club
my ex has an 05 6mt coupe and got the spacer and the engine sounds louder and the exhaust is more burlier and she feels quite a bit more power from the upgrade in combination with the Injen short ram intake...
i was thinking of doing the same thing to mine...
Old Nov 2, 2005 | 04:22 AM
GTT's Avatar
GTT
G35 Twin Turbo
so it's gonna do something in my 05 6mt ... Right
