Straight Pipes vs. High Flow Cats
Old Nov 8, 2005 | 05:08 AM
Dan_K's Avatar
Can someone tell me the pro's and con's of each? Which will produce more power? Deeper sound? Thanks
Old Nov 8, 2005 | 07:59 AM
booger's Avatar
Test pipes will flow better and make more hp up top . They will produce rasp in the exhaust . The RT cats will flow the best out of all the others and also have rasp . The other cats dont flow as well and dont have the rasp
Old Nov 8, 2005 | 08:02 AM
jnkirk1974's Avatar
Fastest G35 In Rockwall
I have Crawford cats and they work great. The RT cats have a history of collapsing.
With the test pipes, you will likely lose a little power on the bottom end and gain it back on the top.
Old Nov 8, 2005 | 08:21 AM
booger's Avatar
Ive had the Crawfords on for a while now . Had the RT's on and they did collapse on me . Going back to pipes for more flow . I guess I'll have to put up with the rasp for more power
Old Nov 8, 2005 | 08:36 AM
jnkirk1974's Avatar
I bet the pipes sound nice. I'd do it too, but don't want to have to take them on and off for inspection.
Old Nov 8, 2005 | 10:57 AM
LEK's Avatar
LEK
That Guy
Does anyone have sound clips for testpipes with stock heads and exhaust?
Old Nov 9, 2005 | 07:03 AM
Dan_K's Avatar
After doing some research, I am going with Labree resonated test pipes. Pricey, similar price to Crawford cats, but I think they are worth it. They have positive reviews and many have no rasp with them. Since I am going FI, I think it would be a better choice. I am probably going to do the install myself, so that I can learn how to do it, since I will have to swap them out with the oem cats for smog later.
Old Nov 9, 2005 | 04:09 PM
P_Diddy's Avatar
If I install Crawford Cats onto my coupe, is there a potential that the car won't pass CA smog or other inspection?
Old Nov 9, 2005 | 06:31 PM
Dan_K's Avatar
I think it should pass. You have cats. I am talking about removing the cats completely.
Old Nov 9, 2005 | 10:43 PM
rocka_fellow's Avatar
With the straight pipe, are you are keeping the stock exhaust right?
Old Nov 9, 2005 | 11:38 PM
Dan_K's Avatar
Yes, you keep your stock exhaust (exhaust, mid-pipe, y-pipe).
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
Th611
Oct 27, 2015 03:48 PM
jbelf23
Forced Induction
Oct 24, 2015 12:32 PM
linedr89
Aug 17, 2015 05:11 PM
