What is the difference between Test Pipe & Y-Pipe
Old Nov 21, 2005 | 06:32 PM
G-Crazy's Avatar
I have decided that once I can figure out how to purchase my exhaust setup without the wife finding out, I am purchasing the Fujitsubo. With this setup, can someone explain if I need a test pipe or Y-pipe. If so, what is the difference?
Thanks
Old Nov 21, 2005 | 06:43 PM
trey's wife's Avatar
My horns hold up my halo
I think I am somewhat confused by your question BUT in case I am reading it correctly here is part of your answer.
The test pipes are to replace the cats on the car and the Y-pipe comes off the cats to connect to the rest of the exhaust. They aren't replacements for one another in any situation that I can recall. You would still need a Ypipe to come off the test pipes to connect up to the rest of the exhaust.
Now having said that, I am not familiar with the exhaust you are looking to buy so I am not sure if it is a catback exhaust or not. Assuming that it IS a catback then it would replace the stock Y-pipe with it's own pipe.
Be careful on hiding things from your wife now. Sometimes we have good reasons for why you shouldn't do things.
Old Nov 21, 2005 | 06:54 PM
SI_G35Coupe's Avatar
in the G35's exhaust system... the headers come off the engine block and come downward out of the engine bay (2 headers, also sometimes call exhaust manifolds)
the catalytic converters ("cats") connect there and route downward and then bend to head toward the back of the car (there are 2 of them) - aftermarket Crawford Cats pictured
after the cats is the Y-pipe. like it's name suggests it's shaped like a Y. two pipes connect to the two cats, and then merge down into 1 middle pipe. (Fujitsubo pictured)
after the Y-pipe comes the midpipe. this is just a single pipe that runs along the middle of the car from the Y-pipe back to the muffler. finally there is the single muffler and a pair of exhaust tips.
the Fujitsubo Legalis-R replaces the factory midpipe and muffler ONLY. they also make the Y-pipe which i highly recommend. if you're looking to upgrade your flow w/o flak from the misses, the cats and the Y-pipe are the biggest bottleneck and replacing them will sound similar to stock just alittle meaner.
Old Nov 21, 2005 | 10:16 PM
^^^ thanks for the info! I wasn't sure if it was in fact a cat back or not so I was hoping someone would chime in on that one.
G35VSHNG37
Oct 25, 2015 08:43 PM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
