Injen Exhaust for the Sedan
Old Jul 31, 2003 | 01:48 PM
PersianG35's Avatar
I talk to a rep at Injen and they said:
"we have finished prototyping and we will have the Sedan specific Super SES available by early September.
Does anyone have anymore info on this?
Old Jul 31, 2003 | 02:47 PM
Carlos3186's Avatar
Re: Injen Exhaust for the Sedan
no but i also emailed them and they said they have one for the coupe comming out around the same time maybe earlyer.
But it is deffently good news
Old Jul 31, 2003 | 03:18 PM
Gsedan35's Avatar
I don't really care for the muffler's those things use, but I do wonder if it will be a true dual?
Ivry 6mt sed
Injen CAI, 22" resonator
8X18 Enkei RPM2 45mm
Kumho MX 245/40
350Z springs&struts
Old Jul 31, 2003 | 03:38 PM
Carlos3186's Avatar
yes its a true dual it will be the same set up as the 350Zs
Old Jul 31, 2003 | 06:23 PM
PersianG35's Avatar
This is probably off topic, but I just had their intake installed on my G. Damn service engine soon light is blinking like crazy. Other than that, I resetted the ecu using the gas pedal method. It seems ot have more pickup and I can definately hear the whistling noise. But damn it feels good to have the guys at the car shop gathering around and giving you compliments =]
Old Jul 31, 2003 | 09:21 PM
NismoV35's Avatar
From: Los Angeles, National Socialist Democratic Republic of Facistfornia
Persian,
try Disconnecting your Negative Battery terminal for a while Maybe 30 Minutes or so. This will Re-set your ECU So it will Re-Learn what you did......... This should solve your problem with the check Engine light. Also are you using the Right Intake? There are 2 diffrent ones for the Auto and the 6MT..... RD 1990 is for Auto and RD 1992 is for 6MT
NismoCPV-35
Old Jul 31, 2003 | 10:16 PM
DaveO's Avatar
You might check out the pictures of Stillen's true dual exhaust prototype under my thread...
"Sedan Owners - Catback Exhaust Systems"
DaveO
Old Aug 1, 2003 | 10:09 AM
PersianG35's Avatar
You know it's kind of weird, After I did the gas pedal ecu reset the check engine light went off every time I hit the gas. But when I turned the car off and on again it went away. I tried the ecu reset again with the gas pedal and the same thing happened. I dunno. It's all working fine now I guess. I'm going to try the batter disconnect over the weekend and see if it makes a difference.
Muski_G
Dec 1, 2023 11:11 AM
Cam_Cooper3
Intake & Exhaust
Aug 10, 2015 07:04 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
Black_Out
Intake & Exhaust
16
Aug 1, 2015 08:44 PM
