MAF Question
Old Jan 8, 2006 | 06:24 AM
louielou's Avatar
Question MAF Question
Can you damage a MAF if its accidentally dropped?
If so, What are the systems of a damaged MAF?
Old Jan 8, 2006 | 08:40 AM
binar's Avatar
You sure you didn't drop it on purpose?
Anyway, here is what the MAF does:
Mass Air Flow Sensor (MAF)
The mass airflow sensor is placed in the stream of intake air. It measures the intake flow rate by measuring a part of the entire intake flow. It consists of a hot wire that is supplied with electric current from the ECM. The temperature of the hot wire is controlled by the ECM a certain amount. The heat generated by the hot wire is reduced as the intake air flows around it. The more air, the greater the heat loss. Therefore, the ECM must supply more electric current to maintain the temperature of the hot wire as airflow increases. The ECM detects the airflow by means of this current change.
So you basically the Engine Control Module would get erroneous or no signal
from the Mass Airflow Sensor and your engine will run crappy accordingly. You
will also get a 'check engine' warning light.
Hope this helps.
Old Jan 8, 2006 | 02:35 PM
louielou's Avatar
Thanks...I did drop it twice. it slid of the engine cover while juggling not to loose my bolts in the engine bay twice. After all of that one did fall in, but I recovered it. (took me 15 minutes) I could find that thing with the under cover on and I didn't want to take it off because then I had to pull out the jack and it was 9:00 pm.
My MAF is operational. I just had to reset the ECU overnight. My SES was on and the manual reset wouldnt work...or maybe my timing was off.
Old Jan 26, 2009 | 04:13 PM
realgone's Avatar
Widdle ya into kindling
Will there always be a check engine light if the MAF is not working properly?
Years ago when I first got the car I installed a z-tube and K&N filter and am wondering if my sub par 14 mpg even when driving like a grandma can be attributed to the MAF. I did do an ecu reset at the same time, not sure if that makes any difference with the check engine light.
Your expertise towards my education on the subject is greatly appreciated.
Old Jan 26, 2009 | 08:29 PM
Hydrazine's Avatar
MAF problems can certainly cause that.
If its broken, replace it.
If its dirty, clean it.
Old Jan 26, 2009 | 10:47 PM
realgone's Avatar
How do you know if there is an MAF problem? I got know problem fixing it or cleaning it, but how do I know, should I take it to the local Nissan dealership and ask them to check out the MAF?
Old Jan 26, 2009 | 10:57 PM
Hydrazine's Avatar
They can diagnose it for you.
If you are getting 14MPG it will be worth the cost.
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
