Invidia G200 Exhaust Install Questions...
Old Feb 18, 2006 | 07:28 PM
IPGThreeFive's Avatar
Does the passenger side pipes go overor under the rear sway? also does anyone have any pictures of the pipes installed..under the car, not the muffler just the pipes...
Old Feb 21, 2006 | 12:01 PM
pdjafari's Avatar
ummm lemme think i know i had the same question when installing...
if i recall I had to run the pipe up above the rear sway. so basically the pipe should run under the car floorboards but not touching obviously. you can verify this when installing just by seeing if the holes will line up. but im about 90% sure it goes above the rear sway...
StreetStandard
Exhaust-Vendor
11
Jan 12, 2016 03:21 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
nickmcc123
Aug 20, 2015 03:10 PM
Ray Feta
Aug 13, 2015 11:40 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
