350Z XERD Headers on a Sedan trial fit
Old Sep 5, 2003 | 06:10 PM
3point5SE_Auto's Avatar
In a post in the Fresh Alloy Z section, a sedan owner asked if the headers would fit a sedan. http://forums.freshalloy.com/ubbthre...b=5&o=&fpart=1
see link.
For you guys, I will have a set of these late this month and fit them up to my sedan. I will not have before and after dyno's unless someone wants to cough up 50.00 for a dyno session, but I will have before and after 1/4 mile times. I will most likely dyno after I put them on and having run the 1/4 a few times, I can extrapolate to within a few hp what the gains are.
www.xerd.com
the z link above mentions that there will be a group buy for these. These look good for expanding the power band on the Z, I hope the same is true with my sedan
I like em cause they are stainless steel and remove the cats, so will save some lot amount of weight.
Better Life thru Chemistry
Old Sep 6, 2003 | 12:38 AM
Gsedan35's Avatar
Re: 350Z XERD Headers on a Sedan trial fit
Read the thread on these headers going on at my350z.com.
http://www.my350z.com/forum/showthre...threadid=40564
It's long, but raised question's in my mind.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Old Sep 6, 2003 | 06:23 PM
I will probably still go thru with it, as I have no problem going down there the next day after they fail to live up to a promise (naturally right after I cancel the payment on the credit card)
Also, as far as the hp claims and dispute on the board there, you will need a SAFC system to maximize the gains from headers. The headers on a VQ with 370 cc injectors will reach 80% duty cycle (theoretical maximum) at ~290 crank hp. After that you run the risk of running extremely lean (like 15 or 16 to 1 ratio)
Options are SAFC, Greddy E manage, larger injectors, larger fuel pump, FPR or a combination of the above.
teamghost
Jul 28, 2015 04:52 PM
joedaddy1
Jul 28, 2015 02:58 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
LoSt180
Jul 15, 2015 08:31 AM
