I have a 05 AT that got 234 RWHP on a mustang dyno on a 68 degree day.
Question is I just ordered a Copper Iso thermal 5/16 spacer, a pop charger/ztube, and a grounding kit. How many RWHP should my car go up and how much BHP should I have after these mods are installed. Pop charger says 6.5, the grounding says 3hp, and the Spacer says 11. So am I really going to be adding 20.5 RWHP or is just all just advertisement bs?
so the pop charger/ztube and grouding kit dont add jack huh?
Any other relatively cheap mods that add some good RWHP?
Im thinking after these mods the final ones I was gonna add were
Stillen sway bars, and maybe High flow cats?
I wonder if the cats add any power. But yea Im not looking for F/I power. Just a little more power than stock and I am set.
Depends on the forced induction route you take. If you go supercharger then add a set of headers and new midpipes. If you go turbo skip the headers, but still pickup some o/r test pipes.Originally Posted by lightforce18
Im thinking after these mods the final ones I was gonna add were Stillen sway bars, and maybe High flow cats?
Im installing the parts in May. Sometime this summer I will re dyno it and see how much I really gained.
234rwhp on a mustand dyno for a stock 5AT is very impressive. I only wish that mine can be that good.
I'm sorry that I don't have any answer for you. But soon I will. I'm trying to prove something
They may have been unloaded numbers, so more like a dynojetOriginally Posted by ATL_Red_G35
Whats unloaded #'s mean?
I heard mustang usually give lower #'s. This guy in a 05 350z with an injen exhaust and manual put up 255 RWHP that day.
Seems like my run was pretty good for an AT. I tried keeping my AC on all morning. Someone told me that keeps your car cooler and gives you higher dyno reads?
Unloaded means they do not load the dyno. They calibrate it with the weight of your car, but do not apply a load. Kinda makes it give numbers more like a dynojet.Originally Posted by lightforce18
Whats unloaded #'s mean?I heard mustang usually give lower #'s. This guy in a 05 350z with an injen exhaust and manual put up 255 RWHP that day.
ahh ok I have no idea if they did or not. So are you saying the #'s are inflated? that a stock 5at cant get 234? because my friend with 5 or 6 mods on his 04 5at dyno'd 238 RWHP on a dynojet. He was like it could be error that you got 234 stock.
He was expecting 210-220 RWHP stock. I dont know he probabaly is right could be an error.
