Just ordered MD 5/16".buyers remorse
Old May 4, 2006 | 10:59 AM
shredX's Avatar
Now I'm wondering if I should have ordered the 1/2".
Is does not seem that the 1 hp diff is worth loosing the use of the engine cover.
I'm hoping to feel a little bit of improvement, but the dyno's do not appear to show any real change until 4k+ RPMs. I do love the sound of my Z tube & hope this makes it even sweeter.
Any comments are welcome... (I prob could change the order if I do it soon)
Old May 4, 2006 | 12:31 PM
G35_TX's Avatar
5/16 you can still use your engine cover I believe.. At least my Z cover fits fine with the 5/16" spacer.
Old May 4, 2006 | 02:00 PM
ma_sha1's Avatar
spacer
I had a 1/2" MD spacer for 3 month. Sound louder.
Actually got worse 1/4 mile time with it than without it.
Took to dealer, found lean signals repeated 30 times in the dianostic machine.
took a small loss & sold it to the next victum,
Old May 4, 2006 | 02:16 PM
shredX's Avatar
Do you recommend no spacer at all???
What does it mean to run lean?
Old May 5, 2006 | 06:34 AM
NETSHARK's Avatar
shredX trust me you will not be disappointed with the sound at all it just sounds more deeper than before !! installed my MD 5/16 Spacer two days ago, it pulls harder i`ll dyno it after two days to check what i gained from this great mod i recommend MREV2 with 5/16 these two mods will give you similar gains to the 1/2 spacer without the need to take off your engine cover
Old May 5, 2006 | 08:19 AM
G35sedan03's Avatar
Personally I lilke the engine without the cover. I know it's about how you like it, but that engine cover is just a heat trap. Our engines run hot as it is and doing away with the cover may just help a little bit, then again i like the plain look anyway.
Old May 5, 2006 | 09:17 AM
G35_TX's Avatar
That's why I like the 350z cover. Doesn't trap heat over the intake manifold.
Old May 5, 2006 | 10:38 AM
dovla's Avatar
Please explain. Did you have air leak? Or your Air/Fuel Ratio was too lean? Any other breathing mods? Which diagnostic machine - Consult 2? Thank you
Old May 5, 2006 | 04:38 PM
shredX's Avatar
Thanks for the words of encouragement. I'm sure there are many more happy vs unhappy customers. That's why I ordered the d*** thing anyway. It's just that I read that alarming thread...
Anyway, I never thought about the engine cover being a heat trap. Hmmm.... I'll have to think about my options.
Side note: Just ordered the HKS rear section today. Next week (k&n drop in + z tube + 5/16 spacer + HKS) my car should be sounding pretty sweet.
I appreciate all the comments.
Old May 6, 2006 | 12:58 AM
techi13's Avatar
the plastic engine cover is better off then on and heres my logic...
no one really looks at your engine bay, and the damn plastic cover traps a lot of heat under there...your engine will run cooler and dont forget the weight reduction (like 3 lbs) ^^
Old May 6, 2006 | 08:17 AM
NETSHARK's Avatar
Later on am gonna order a 350Z CF Engine Cover with TS CF Hood, the plenum will cool up much better.
Old May 6, 2006 | 09:02 AM
DaveB's Avatar
I agree the cover is a bit of a heat trap, but you can be assured that once the intake manifold becomes heat soaked, it doesn't matter if the cover is on there or not. At the track, I don't run with the cover, but I can tell you that with a cold intake manifold or a scalding hot intake manifold, the car performs no differently. It's 14.3-14.4@97+ all day long. The car is incredibly consistent.
Old May 6, 2006 | 05:01 PM
shredX's Avatar
...good stuff
dcsbh1
Oct 1, 2015 03:15 PM
Detailed Image
Sep 28, 2015 07:04 AM
