Help on installing the grill..=(
Old Jul 18, 2006 | 12:21 AM
acs2's Avatar
i'll being trying to take off the oem grill on a 04 coupe for almost an hour
but still can't figure out how the hell to get it off....=(
i took the 6 nail-like plastic things off...
then i have no idea wut to do after that..=( anyone help!!
Old Jul 18, 2006 | 12:28 AM
Andy2434's Avatar
Look in both the upper right and lefthand corners of the grill with a flashlight. You will see 2 plastic square shape fasteners, which are turn diagnal to 2 square openings. With a screwdriver turn the 2 fasteners until they each line up with the openings. The top of the grill should be loose at this point. At the lower portion of the grill there are a number of plastic tabs, which are inserted into the bumper structure. Simply grab hold of the lower portion of the grill and pull outward. Good luck!
Old Jul 18, 2006 | 12:40 AM
speedraver's Avatar
wassupMyNinjas! (^_^)
https://g35driver.com/forums/showthr...m+grill+remove
Old Jul 18, 2006 | 07:28 PM
SCSHAY's Avatar
i have something elses
i have got my oem grill off
but now how do ui get my jdm one on there are no clips on the bottom of the grill
i know drill holes in the top but what do i do for the botom of the grill???
Old Jul 18, 2006 | 11:48 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I think it just sits there, I think i remember some1 sayin you can use 3M double sided tape too.
Old Jul 19, 2006 | 01:36 AM
SCSHAY's Avatar
ya thats what i will do thanks
G-MAN (CANADA)
Canada
Sep 7, 2015 03:51 PM
3000vr4tt
Sep 7, 2015 12:48 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
