My Own Bumper Plugs, Way Cheaper
Old Jan 11, 2007 | 02:51 PM
2001Z71's Avatar
DIY: My Own Bumper Plugs, Way Cheaper
Did you take your license plate off and find 2 ugly holes in your bumper?
And did you find bumper plugs for $30? And did you then think of how rediculous $30 is for those little things?
Yeah, I thought it was rediculous too so I made my own
Heres how to make your own Bumper plugs for $10:
Supplies needed:
Hillman 7/16 Nylon Hole plugs (Black)
OEM Touch Up paint
Spray Enamel
220 grit Sandpaper
Pocket knife
Steps:
1. Go to your local Lowes or Home Depot and buy Hillman 7/16" Nylon Hole plugs in Black. Also buy some spray enamel or clear coat for added durablilty.
2. Buy OEM touch up paint if you dont have some already. Its about $8.00 and you will need it in the future anyway.
3. The plugs are not smooth on the top, so I sanded them with 220 grit sandpaper, which will also help the paint adhere. Wipe them off so no plastic dust is left.
4. Set the plugs so they will be easy to paint and will not get knocked over, I just pushed them in about 1/4" into a piece of styrofoam.
5. Shake up the touch up paint for a long time, then apply a thin single coat of paint to each plug. Let them dry for 20-25 minutes. Repeat this step as many times as necessary. (I used about 6 coats)
6. After they are totally dry, I hit them with 3 coats of spray enamel (about 10 minutes apart) for added durabilty. Then let them dry for a day or so.
7. The 7/16" plugs wont fit in the holes, you need to bore the existing holes out ever so slightly to ensure a tight fit. I used a pocket knife and did one round in the hole. After that the plugs will barely fit, you have to push them in. Be very careful not to make the hole too big!
8. Pop both of those babies in and bam! Youre done. Then take your girl out to dinner or something with the extra $20 you saved
Here are a few pics:
Before with holes:
After with bumper plugs:
Old Jan 11, 2007 | 02:53 PM
Meatshackle's Avatar
Deep Sea Moderator
I don't need these but I'm sure the people that do would like to know how you made them.
nm3th's Avatar
Nice...care to share how you did it?
Old Jan 11, 2007 | 02:56 PM
Calvin's Avatar
Overglorified Altima
go to lowes. find some plugs for a buck or two. get some touch up paint. paint away. plug that ish in and poof.
i assume you did something similar?
Old Jan 11, 2007 | 03:12 PM
2001Z71's Avatar
Check the first post again
Old Jan 11, 2007 | 03:23 PM
Calvin's Avatar
should post this in the DIY forum for others to find
thanks for the write up
Old Jan 18, 2007 | 12:21 PM
OU812G350's Avatar
i did the same with 2 black plastic license plate bolts..they screw right in the holes made by other screws..then prep and paint if u wish........
Old Jan 18, 2007 | 02:17 PM
GreenGoblin's Avatar
The goblin resurrection
good job glad I dont need a front plate
Jyounya
Sep 12, 2015 04:03 PM
Jyounya
Sep 12, 2015 02:29 PM
twentyeggs
Sep 11, 2015 03:58 PM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
jbmw002
Sep 3, 2015 08:42 PM
