Pillar Guage Help Please
Old Feb 19, 2007 | 11:15 AM
KenK2's Avatar
The Pole
Hey fellas..
I need to install my 3 guage pod w/ Autometer Nexus guages. I tore into the dash a little bit but am not sure how I am going to get the 1 wire run from the pillar to the control box over by the dash.. Can anyone shed some light on this for me?
Thanks
Ken
Old Feb 19, 2007 | 02:02 PM
Meatshackle's Avatar
Deep Sea Moderator
Where is the control box?
If it's on the pax side you can just run the wire down the pillar, under the dash on the driver's side, behind the center console and it will come out under the dash on the pax side. Use a coat hanger to feed the wire behind the console.
Old Feb 19, 2007 | 03:04 PM
KenK2's Avatar
The Pole
Yea the control box is over on the Pass. side.. My main concern was getting it run along the underside of the dash from the drivers side to the pass side.. I didnt even think of a coat hanger and will try that. There wasnt much room at all when I took the old pillar off and tried to find an opening to run the wire
Old Feb 19, 2007 | 09:17 PM
Deep Sea Moderator
There's lots of room there. I have my V1 wire, wires for 3 gauges, and my sunroof module wires running through there. The coat hanger is your friend.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
g.spot
May 9, 2016 10:54 PM
alessandro
Oct 8, 2015 09:29 AM
