My headlight aiming
Old Mar 13, 2007 | 03:53 PM
mubay's Avatar
My headlight aiming
Somebody help me with my headlight aiming.
My friend told me that one of my projector aim lower than the other one.
So, to proof that, i headed my car against the wall and turn the light on, i assume my right headlight aim higher than left side because the line look like this
____/---------center --------------
Is it normal?
So i searched and found some threads about cutoff. If i'm not mistaken, the cutoff only produce by my left headlight. [i'm not really understand about that].
I have some picture with my phone camera. I'll borrow my friend's 10mp camera and take a few shoot tonight.
What do you guys think? should i adjust my headlight?
Attached Thumbnails My headlight aiming-c.jpg   My headlight aiming-d.jpg   My headlight aiming-e.jpg
Old Mar 13, 2007 | 04:01 PM
redlude97's Avatar
Your cutoff should look somthing like this, with the bottom 2 steps aligning and the top two steps aligning
_________/============/-------------------
Old Mar 13, 2007 | 06:33 PM
IvoryGT's Avatar
Both has cutoff, it just overlaps the passenger side. Your aim is too high on left or too low on right.
Basically at a distance of 25ft. The highest point of your lights should be 2~3 inches lower than the height of the projector off the ground.
Old Mar 13, 2007 | 09:44 PM
cutiewolf's Avatar
i dont know about other,but my i can adjust my 03 headlight aiming. just pop ur hood ull might able to find a little hole u need to use screw driver to adjust it.
Old Mar 14, 2007 | 12:40 AM
mubay's Avatar
do you know which one is the 8mm bolts that used to adjust the projector?
I red circled two bolts on the picture. Which one is it? The one on the left or right? or neither of them?
I use a picture from other threads.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
