INGS face duct mod
Old Apr 4, 2007 | 12:54 PM
brianmfournier's Avatar
INGS face duct mod
I've has these replicas on my coupe for a few months now and decided to tweek them a little. I like the look of the nismo bumper (see below), but between getting married and buying a house, it's not really an option.
So, I've decided to so a little a work on them by removing the center bar and patching the holes. It's my first time doing any work with fiberglass, so go easy on me
Here's what I started with:
Center bar cut,
And sanded:
One side filled:
This is far as I got today, unfortunately I'm off to work, and busy until next week. I've only rough sanded and still need to go back and do some work with finer grit paper. When I've gotten more accomplished, I'll update the post.
Thanks,
Brian
Old Apr 4, 2007 | 12:56 PM
filanj's Avatar
where did u pick up those inserts?
Old Apr 4, 2007 | 01:01 PM
I got them from a member here, but after a while decided to try something new
Old Apr 4, 2007 | 01:03 PM
filanj's Avatar
Oh, okay. Do you know where I can buy them? I have bats inlet overlays, but they are ripping and look like **** now after a couple of washes.
Old Apr 4, 2007 | 02:13 PM
Calvin's Avatar
Overglorified Altima
g35putih used to sell replicas of these. PM him to see if they are still available.
Old Apr 4, 2007 | 04:47 PM
filanj's Avatar
/\ thanks cal. I'll check with him
Old Apr 4, 2007 | 05:13 PM
Calvin's Avatar
np, it's been a while since he's sold them though. not sure..
member "silverbolt" has replicas from g35putih though.
Old Apr 7, 2007 | 07:13 PM
Almost there
One duct has been filled and sanded out:
The other has been filled roughly and is awaiting sanding.
Hopefully it will be done next week, and then I need to final sand the pieces and paint.
Thanks,
Brian
Old Apr 8, 2007 | 02:02 PM
88G35's Avatar
Good luck with the rest of your modification to the inserts. I think it will look good, something I might consider in the future since my front bumper needs replacing. I can't wait to see it all done.
Old Apr 8, 2007 | 02:12 PM
redlude97's Avatar
I hope you did more than just fill that area with bondo/filler or else it will crack soon.
Old Apr 8, 2007 | 07:03 PM
Yeah, there's a small piece of wire mesh that you would use to fill a hole in a car body inserted in the empty space. I am worried that it still may crack in the future but we'll see. If it does, I guess I'll have to start over again, maybe with some fiber glass instead.
Old Apr 9, 2007 | 01:03 AM
redlude97's Avatar
I would use some reinforced fiberglass as well, or at the very least the mesh with some "kitty hair" fiberglass impregneted filler. Bondo type fillers aren't meant to be applied more the 1/16-1/8" thick
Old Apr 9, 2007 | 01:20 AM
akachi's Avatar
sweet.....
Old Apr 9, 2007 | 02:35 AM
IvoryGT's Avatar
looking good. I love DIY projects. It's awesome that there are still people willing to do some original work themselves.
Old Apr 9, 2007 | 06:57 AM
The area that I used the filler in is very thin after sanding, probobaly about 1/8" thick. Like I said, if it falls apart, it's no big deal. I'll just start over with fiberglass.
