Top Secret Mirrors
Old Apr 17, 2007 | 10:18 PM
j-velocity's Avatar
Does any one know if the one for 350Z are the same as G35?
Thx
Old Apr 18, 2007 | 12:39 AM
Calvin's Avatar
Overglorified Altima
350z and g35 mirrors are slightly different. 350z mirrors requrie some modification.
Old Apr 18, 2007 | 02:07 AM
j-velocity's Avatar
But is the mouthing base the same?
thx
Old Apr 18, 2007 | 02:18 AM
Calvin's Avatar
nope.
Old Apr 18, 2007 | 06:27 PM
INTENSEPOWER's Avatar
Hello,
Thanks for the order Scott! I'll keep you posted on a delivery date!
-Mike
Old Apr 18, 2007 | 06:35 PM
HYBRID ITR43's Avatar
Thanks for making it easy.
Old Feb 20, 2008 | 12:50 AM
thatg's Avatar
hey back to this, craftsquare makes a mirror for the 350z so could i make that fit with minimal modifications?
Old Feb 20, 2008 | 12:58 AM
EricIsKlumzyee's Avatar
Hello, I have the TS
You'll need to drill 3 seperate mounting points into the car. Don't worry it wont change the OEM points at all so you can easily reinstall your OEM mirrors with NO PROBLEMS =) HOWEVER you have two ways to go with the triangle piece that bolts to the door. You can either shave/modify it to fit. OR you can modify your weather strip and be creative about the mirrors (What I did). If you do this.. you wil need to do some trial and error because you're milimeters away from hitting the outter A-Pillars.
- Eric
prinny
Nov 22, 2015 11:07 PM
BradMD_96
Oct 6, 2015 09:31 AM
the93owner
Sep 28, 2015 10:37 PM
master111
Sep 25, 2015 08:32 PM
