Do i need to keep sanding?!?!?
Old Apr 25, 2007 | 09:32 PM
DrewTheSuit's Avatar
Well i'm trying to prep my oem grill before having it painted, and was wondering how everyone else sanded their's...i'm doing this by hand if it makes any difference...so far i have only sanded the left side if you are looking at the car...i used med grit so far and plan to follow up with some fine grit, but does the left side look like its ready for the fine grit
OEM finish side
SANDED side
Old Apr 25, 2007 | 11:57 PM
IvoryGT's Avatar
I don't know what number grit you are using...if you are going to paint it yourself. then I would send it down completely smooth with 150 grit so it will ensure a safe adhesion. If it's going to be painted by a shop. Just make sure the whole thing is uniform..they will do the rest.
Old Apr 26, 2007 | 02:36 AM
for those that did this themselves, did the grill look like brushed aluminum when you were done? i've been sanding this thing for hours expecting to find plastic underneath it all, but all's i've got is a light silver color similar to the dash trim
Old Apr 26, 2007 | 02:43 AM
aleok's Avatar
^ there is plastic under. just keep sanding if you want, i did.
Old Apr 26, 2007 | 02:55 AM
what color was the plastic you hit?
Old Apr 26, 2007 | 03:02 AM
redlude97's Avatar
down to the metal is fine, then primer and paint
Old Apr 26, 2007 | 07:45 AM
aleok's Avatar
...cream..
skippyG
Jan 25, 2016 01:18 PM
Extreme Dimensions
Southern California
Oct 19, 2015 06:28 PM
Nickles
Sep 1, 2015 08:11 PM
propho
Audio/Video/Electronics
Aug 27, 2015 04:56 PM
newg37
Jul 26, 2015 09:32 AM
