True Chrome OEM Grille Possible??
Old Apr 28, 2007 | 04:14 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Question True Chrome OEM Grille Possible??
I tried searching with no luck....
I want my entire grille to have the same chrome appearance as the infiniti grille logo. I noticed the grille itself has a tinted chrome look but I also noticed in spots where it has chipped that it is normal chrome underneath.
Has anyone ever tried or know how to get that tint layer off w/o messin the chrome under it
Thanks
Old Apr 28, 2007 | 04:19 PM
DrewTheSuit's Avatar
i considered leaving my grill unpainted after i sanded it...it looked like brushed aluminum...it would't really work with the look i'm going for, but it didn't look bad ...not sure how you could get just a chrome look, they do make "chrome" spray paints but i don't have any experience with those to give a positive recommendation. good luck
Old Apr 29, 2007 | 02:23 AM
ebony350's Avatar
It is possible to chrome plate plastics, but I have no idea where to start searching. I sat next to a guy on a business flight once, who claims his company invented the process.
Old Apr 29, 2007 | 03:14 PM
GreenGoblin's Avatar
The goblin resurrection
i think it is called vaccum bagging chrome
Old Apr 29, 2007 | 04:03 PM
redlude97's Avatar
Not vacuum bagging, but rather vacuum metalization or vacuum deposition. Basically they put the part under vaccuum so they can vaporize copper and aluminum at a lower temp so it doesn't melt the plastic, which then gets deposited onto the plastic piece. Then a tinted clearcoat gets applied for durability. If you can strip the clearcoat without harming the metal underneath, then you can have it recoated with nontinted clear and it will be "chrome"
Old Apr 29, 2007 | 11:29 PM
Infinite_R's Avatar
Yaaaah Yaah Trick!!
Yeha that part I'm trying to figure out how to do. I'm going to try and find a test grille to try differ ways a getting that tint off.
jsimonk
Dec 22, 2023 03:49 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
rymian
Sep 9, 2015 08:03 PM
Gomer
17 Inch
Aug 13, 2015 08:53 AM
