View Poll Results: OEM Vs JP Vizage
OEM
41
65.08%
JP Vizage
22
34.92%
Voters: 63. You may not vote on this poll
OEM Vs JP Vizage
the only thing that bugs me about the jp is the sides they seem wider than the oem , but it makes it look like a cheap paste on rather than complementing the lines of the car... but its chunkier center attracts me.
i just went thro the same issue.. i decided on just going with the oem front lip... its perfectly keeps the lines of the car and the corners look perfect... i dont mind that it thins out in the middle either, it makes it look like less of a lip and more like an actual part of the bumper
G35 Coupe "Sport Package"
Not much visible difference except what you said about the sides not fitting too well. I have OEM and fitment is perfect and paint was perfect match, no worries. Check out the INGS front lip if you want fat. But if these are the choices, I say OEM.
i know that the jp is goin for something like 380 shipped, not sure on the oem since i couldnt really find a vendor,
https://g35driver.com/forums/exterior-vendor/155455-jp-vizage-lip-stock.html
I'd say be different and go with the Vizage, everyone has the OEM lip.
Picture from the side, matches perfect with the lines of the factory sides.
Originally Posted by kenempireex
which one is cheaper? They look pretty much the same
