Seibon carbon fiber fenders and doors
Jun 20, 2007 | 03:15 PM
Hey guys, happy to annouce a few new parts available from Seibon.
Seibon G35 coupe 10mm carbon fiber fenders
Seibon G35 coupe carbon fiber OEM doors
They are due to arrive middle of July.
There are a limited number being offered off the first shipment. I'll get pictures as soon as they arrive stateside. PM me for pricing.
Thanks !
Jim
Reply 0
Jun 20, 2007 | 06:08 PM
Omg ! Sweeet !!!
Reply 0
Jun 20, 2007 | 07:14 PM
wow nice
Reply 0
Jun 20, 2007 | 07:42 PM
wow doors that is nuts im sure that will be a significant weight drop with all the bracing in there
Reply 0
Jun 20, 2007 | 09:05 PM
sweet
Reply 0
Jun 20, 2007 | 09:51 PM
cool this is perfect for my firend with his LR g35 coupe with CF ts front bumoer and oem cf hood with cf oem fenders
if you had some side skirts to go with those doors omg, he will be on hs way to a fully cf g35c which i would love to see, right now i think it looks a bit off without the cf side skirts
congrates on your new product and cant wait to see the pix
Quote: wow doors that is nuts im sure that will be a significant weight drop with all the bracing in there
theres only 3 brace bars made out of aluminum in our doors, its like our hoods, if you chnge to a cf hood not much weight lose,
since the braces are made out of aluminum really not much weightloses, the window reg/track etc.. weights more, but you should lose some weight with the change of the door shell i would think
ps...Carbon: russ's ts cf hood fit nicly, only needed to grind down the latch on it a bit and it fit mint
Reply 0
Jun 20, 2007 | 10:51 PM
cool cant wait to see pictures.
Reply 0
Jun 20, 2007 | 10:56 PM
I am inn....
Reply 0
Jun 20, 2007 | 11:49 PM
Quote: ps...Carbon: russ's ts cf hood fit nicly, only needed to grind down the latch on it a bit and it fit mint
Awesome man, good to hear it went well...now get some pictures
Quote: I am inn....
I knew you'd be in on this
Reply 0
Jun 21, 2007 | 03:08 AM
finally....I assume these are dry carbon doors.
Reply 0
Jun 21, 2007 | 03:19 AM
any idea if the doors will dent like the regular doors we have now?
i hate door dings
Reply 0
Jun 21, 2007 | 04:40 AM
if you paint them...it will show..if not..you might get chips off the resin/clear coat
Reply 0
Jun 21, 2007 | 06:14 AM
dry carbon????
coming from Seibon, possible, but not probable.
you realize the cost of dry carbon doors rival that of an installed FI kit??? big balla if you get dry carbon doors
Reply 0
Jun 21, 2007 | 07:05 AM
then..how much weight does that save you and also the rigidity is not all that especially without the supports...suppose you get side swiped...
Reply 0
Jun 21, 2007 | 07:10 AM
i am pretty sure you retain the stock doors, the carbon fiber piece is simply the door skin.
Reply 0
