Which bulb number or LED type do I need? (pic)
Old Jun 29, 2007 | 01:07 AM
chrispyy's Avatar
As the thread states, which bulb number or type of bulb/LED goes into this? Just found out that this side wasnt working but the other one was. Thanks guys!
Also, links would be helpful to where i can buy them.Thank you.
- Chris
Old Jun 29, 2007 | 01:25 AM
rookie's Avatar
Should be a 194/168 wedge bulb. vleds and autolumination are 2 sources.
Old Jun 29, 2007 | 01:35 AM
chrispyy's Avatar
is there a certain color i should get?
thanks for the reply rookie
Old Jun 29, 2007 | 01:39 AM
Calvin's Avatar
Overglorified Altima
this is pointless. it won't be any brighter. trust me, because i've done it.
color doesn't matter since the lens is red. just get white. anything else might made a weird mix...
my suggestion - don't waste your time.
rookie's Avatar
I suppose white, not sure how much of a difference a LED will be in that red housing. Could be a tad brighter than the little halogen ones.
Old Jun 29, 2007 | 01:40 AM
Calvin's Avatar
^^^exactly. if there was any difference at all, it was minimal for me. btw - i used vleds.
Old Jun 29, 2007 | 11:11 AM
chrispyy's Avatar
yep, im just trying to find the right one to match the other side because that side burnt out. im trying to find the one that will match, even if its a halogen. so its definately a 168/194 bulb?
anyone know where i can get the halogen bulb so it will match the other side and what type of halogen bulb is it?
thanks guys for helping me out.
Old Jun 29, 2007 | 12:28 PM
Calvin's Avatar
assuming you have clear corners now, do you still have the bulb from your amber corners? it's the same one.
Old Jun 29, 2007 | 12:39 PM
sfgr415's Avatar
Calvin... which V-LED did you use? (4 led, 6 led, high power) Did you use a white bulb or a red one? My only concern is that HID white would look weird behind red.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
MarcelDK
Aug 23, 2015 09:01 PM
linedr89
Aug 17, 2015 05:11 PM
