front right fender / bumper clip broken
Old Aug 24, 2007 | 12:42 PM
2004g35graphite's Avatar
Hey,
I need some help in this link below, The white clip to the left above the bumper by the fender is broken on my car. Do you know what the name of the piece or assemply is?
http://www.az350z.com/photopost/data...C02641-med.JPG
I'm not sure if it is # 3 on this link:
http://www.trademotion.com/schematics/3/3840005.gif
or if it is # 7 on this link:
http://www.trademotion.com/schematics/3/3840075.gif
or one of the parts on this link
http://www.trademotion.com/schematics/3/3840080.gif
I appreciate your help Thanks alot
Old Aug 24, 2007 | 12:46 PM
suicidesam's Avatar
****defected****
your link to your pictue blows...use http://www.imageshack.us/
Old Aug 30, 2007 | 03:36 PM
any suggestions
any suggestions
Attached Thumbnails front right fender / bumper clip broken-fender.jpg   front right fender / bumper clip broken-fender-parts1.gif   front right fender / bumper clip broken-fenderparts2.gif
Old Aug 30, 2007 | 03:38 PM
heres more pics
heres more pics
Attached Thumbnails front right fender / bumper clip broken-fenderparts2.gif   front right fender / bumper clip broken-fenderparts3.gif
Old Aug 30, 2007 | 05:06 PM
lowrider's Avatar
Don't know if this will help or not. When I put in my '07 projectors I had an issue attaching the bumper cover on the left side. As I remember it attaches with two bolts, one near the front of the car, that goes in at an angle, and one back near the wheel opening that goes in straight vertical. The front one was OK, but I could not get the rear one to tighten up. The bolt went in from the underside of the bumper into a plastic nut mount attached to the fender. My solution was to take a longer bolt, push it through the plastic mount and attach a metal nut on top of the plastic piece. I then tightened up the new bolt, and it pulled the bumper up snug to the fender.
Lou
Old Aug 31, 2007 | 09:19 AM
thanks alot
thats exactly what happened with my car, but the plastic nut by the fender which the bumper screws into is broken, it will screw in but not all the way. I'm gonna give the nut and bolt trick a shot. thanks alot if you find out what part that is let me know. thanks again.
Old Aug 31, 2007 | 10:53 AM
lowrider's Avatar
When you do this and tighten down the metal nut, it pretty much destroys the plastic nut mount. Why they put plastic there I have no idea
Lou
Old Aug 31, 2007 | 11:55 AM
yeah you know how they make cars now adays they put these crappy parts on them. The plastic piece is shot anyway so it shouldn't matter. thanks for the heads up. I'm gonna try the bolt this weekend.
Old Aug 31, 2007 | 01:22 PM
imalazeeass's Avatar
im using nut and bolt method.. works fine.. just takes more work to secure the inner bolt
Nick_M
Aug 3, 2015 11:08 PM
Nick_M
Aug 3, 2015 05:33 PM
st33zygill
Jul 29, 2015 10:05 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
wylin
Lights
Jul 18, 2015 06:12 PM
