Impul Skirts and Rear Hybrid FRP
Old Sep 21, 2007 | 11:39 PM
G2FAST's Avatar
What is Hybrid FRP?
FRP stands for Fiber Reinforced Plastic, and that is simply what fiberglass is. Fiberglass is considered a plastic in the composites industry. However, there parts differ from conventional FRP aero parts because they use an undisclosed combination of special surface coats, resin, and fabric to give our parts the flexible properties it needs (MUCH LIGHTER). Conventional FRP aero parts are made with a gel coat surface, which is brittle and harder to sand (Something hard and brittle tends to crack easily). Hybrid FRP parts have a flexible black primer surface, exclusively formulate, which is easier to sand and adheres much better to other primers as well as paint. Gel coats do not adhere to paint very well, which is why paint tends to peel off if the part it is not prepped meticulously. Primer is used as the link to adhere the two.
With that said check-out what these guys can do and have:
I will post some pictures of the parts off the car, quality is an A++.
Old Sep 22, 2007 | 04:21 AM
martyg35's Avatar
^^^Isn't that ShineAutoProject's Impul sides and rear replica in FRP? They do make good stuff for the 350z community as seen on the my350z forum.
http://www.my350z.com/forum/showthre...=221726&page=2
Old Sep 23, 2007 | 01:25 AM
G2FAST's Avatar
That sure is, I have been talking to them and trying to get them some work for the G35/G37 community. They are very busy right but they would really like to start making some quality products.
Just need feed back from everyone.
I have these peices at home tested them and good fitment and wow great material. Anyone have any question let me know..........Thanks!!!
Old Sep 23, 2007 | 01:30 AM
Deepdiver's Avatar
Josh, whats with the rivets/bolts under the impuls in the first pic?
Old Sep 23, 2007 | 01:39 AM
Calvin's Avatar
Overglorified Altima
They look like puddle lights.
Old Sep 23, 2007 | 02:12 AM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
that car is almost an exact replica o geeboy79's ride..
Old Sep 23, 2007 | 07:15 PM
G2FAST's Avatar
I will take pictures also so you guys can see the peices..............Also I might not keep my set given to me due to other things I want, so those will be up for sale.
erickLA
Aug 20, 2015 09:53 PM
yoyoyo8
Aug 12, 2015 03:04 AM
st33zygill
Jul 29, 2015 10:05 PM
kenthung
Jul 21, 2015 05:56 AM
