Headlight clip removal
Old Mar 21, 2008 | 10:42 PM
itsmesamp's Avatar
How do you guys disconnect the headlight wire? I'm trying to change my 2005 headlights to the 2006 and find it impossible to disconnect the main headlight wire. Is there a something i press on before pulling?
Old Mar 21, 2008 | 11:43 PM
Sponger's Avatar
6MT Brembo Coupe
The passenger side is a PITA because there's less room to work with. If I remember correctly, you really have to press on the clip for it to release.
Old Mar 21, 2008 | 11:59 PM
g35man04's Avatar
CLUB MODERATOR
you can pull the clip of the headlight...just pull really hard and it should release...it makes it alittle bit easier to un-plug it.
Old Mar 22, 2008 | 12:01 AM
Mike_Deezy's Avatar
The passenger side is a B***H, it was hard for me to press the release clip becuase it's on the bottom and there was no room. I had use a flathead screwdriver to push the clip in order to disconnect it.
Old Mar 22, 2008 | 12:16 AM
Deezflip's Avatar
PITA for sure...you have to remove it off the bracket that it's resting on, but even that's a PITA as well.
You'll barely see the bracket since the wire slack is to it's bare minimum to move the headlight assembly out of the way. You'll just have to wiggle and yank it out blindly, pulling towards the rear of the car.
Once you get that off the bracket you'll have a little more slack to move the headlight assembly and get a better reach/grip to separate the harness.
Old Mar 22, 2008 | 12:57 AM
itsmesamp's Avatar
Would it be a problem if I yank from the wires?
Old Mar 23, 2008 | 11:18 AM
Mike_Deezy's Avatar
I wouldn't suggest that becuase you can pull the wires out of the harness completely, then you'd really be SOL. If you're going to yank it, yank it from the clip, not the wires.
Danielek
May 1, 2022 01:28 PM
lil beezy
Lights
Dec 23, 2015 05:25 PM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
