driver side window problem
Old Jul 10, 2008 | 06:17 AM
VISHAL_G35's Avatar
Hello,
I have a question regarding my driver side window. I am not sure if its the window motor but I noticed sometimes the window won't go up or down sometimes. When that happens, I open the door and close it and it starts to work again. Anyone know what the problem is? I am hoping maybe it could be a loose wire or something other than the motor... what do you think?
Old Jul 10, 2008 | 11:50 AM
cdubel01's Avatar
CLUB MODERATOR
it is prolly the same thing that happened to me. Sometimes there is a carbon build up in the motor housing that causes the copper contact points to not connect. Kinda a pain in the butt, but if you take the door apart and pull out the motor, you can clean out the carbon and everything will prolly work again. My window did the same thing, and I did this and now it works fine. There is a great DIY on here with pics, but I don't remember where. Just do a search. Saved me alot of money replacing things unneccessarily...
Old Jul 11, 2008 | 05:17 AM
VISHAL_G35's Avatar
thanks for the reply!!
I found the DIY
Old Jul 11, 2008 | 06:25 AM
jayremix's Avatar
if you're still under manufacturers warranty, bring it to the dealer and they will replace it with a brand new one. Its better to get brand new and its free.
happened to me and thats what i did.
Old Jul 11, 2008 | 03:15 PM
G Nasty23's Avatar
Mines been doing the same thing for a while now. I found if i lift the window up and then push it back down about a half inch it will start working again. Extremely annoying so Im gunna have to do the damn DIY real soon.
No warranty/money to replace
Old Jul 11, 2008 | 04:02 PM
cdubel01's Avatar
CLUB MODERATOR
the DIY isn't that bad, just takes a little while to take out all the damn bolts...
Old Aug 4, 2008 | 10:28 PM
jaedoggz's Avatar
it your window motor i just replace mine last winter. i had to punch the door while holding the button to go up or down. i took it apart and cleaned out the brushes and it was just an temp fix. go on ebaty any look up g35 window motors. it cost around 170
Old Aug 4, 2008 | 11:08 PM
cdubel01's Avatar
CLUB MODERATOR
I hope that it is not a temporary fix...I cleaned mine about two months ago and it has been working fine since, so....
Old Aug 4, 2008 | 11:46 PM
Cobra-2-G's Avatar
The friggin motor...
Just had mine done 2 weeks ago for the same thing.
Old Aug 6, 2008 | 10:44 AM
w1nkst4's Avatar
mine does the same thing kinda. it goes up and goes down real fast for me. when i do the auto up. i told infiniti and they "tried" to fix it by changing the motor which wasnt the problem. I think its the switch. Im takin my car back to infiniti in a few days to get them to change the switch.. ill tell you how its goes!
mbe093
Lights
Oct 2, 2016 11:09 PM
Ludz
Lights
Mar 28, 2016 02:06 AM
apintojr
Jul 23, 2015 10:52 AM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
