Headlight help!!!!
Old Dec 3, 2008 | 07:56 PM
conrad_s13.5's Avatar
Headlight help!!!!
So the dealer told me it had a bad ballast,.. and was gonna charge $300 to fix it, ( i have a 04 coupe btw...lol )
i have aftermarket HID's on my 240 so i know those would work fine, for a cheaper cost too.
i got the HID's, hooked it all up and nothing
idk if my car has a headlight fuse that may have blown?.....my other cars do, i just cant find it on the G anywhere.
there is also a yellow (looks like) ground wire from the harness from the OEM bassast that my aftermarket doesnt have,..idk if that could be the problem!
just help me nukkKas!....pretty prease!
Old Dec 3, 2008 | 08:06 PM
redlude97's Avatar
Just go by to OEM, and purchase a used OEM ballast from ebay. Your aftermarket ballasts will likely die soon anyways. Then check all your fuses including the ones behind the battery
Old Dec 3, 2008 | 08:11 PM
i already bought the aftermarkets,...and im kinda a DIY'er...lol
IS there a headlight fuse?.....u said behind the battery?
Old Dec 3, 2008 | 08:16 PM
redlude97's Avatar
if you are a DIYer then you should know how to check all your fuses to see which one is blown
Old Dec 3, 2008 | 09:57 PM
hmm?
i know how to check fuses.....***!....lol
jk
but im guessing you dnt know then.
so if anyone else can help me, just askin' if there is a headlight fuse i cant find......or a connection im missing somewhere on these HID's
Old Dec 3, 2008 | 10:03 PM
ON's Avatar
ON
are you trying to hook-up an aftermarket ballast to the stock bulbs?
Old Dec 3, 2008 | 11:06 PM
No sir, but the bulbs do look similar.
I got new bulbs and ballast,.. ballast hooks up to stock ballast harness,...and then new harness that hooks up to the bulb. OEM has a ground connected to it ( where ballast meets bulb ) that the aftermarket doesn't have...so that could be a problem ( I doubt it but... ) idk, I can see how this would be confusing...lol
I could post pics later if that'll help
Old Dec 4, 2008 | 12:33 AM
ON's Avatar
ON
yes. pics would help. I need a visual.
Old Dec 4, 2008 | 02:26 PM
mk,.. ill take some pics, and post them up,.. ima give it another shot when i get off work, so if i can find this "headlight fuse" that exists, maybe thats the whole problem.....................hopefully
Old Dec 4, 2008 | 02:32 PM
redlude97's Avatar
Originally Posted by conrad_s13.5
hmm?
jk
I know exactly how the headlight wiring works and how to wire up ballasts(OEM or aftermarket). It seems you don't know because you aren't able to pinpoint your problem and asking a very generalized question which can't be answered with more information. Try hooking the ballasts up directly to the battery and see if they light up the bulbs, that would eliminate them being an issue. Reconnect your 1 good ballast and see if that still works. That should eliminate a fuse issue. Otherwise, take it to a shop that knows what they are doing so they can diagnose your wiring.
Old Dec 4, 2008 | 02:49 PM
lol....simma dude.
i know how the wiring works too man,..i just asked 2 simple questions and your yet to answer 1, and talkin' down to me like i dnt know ****.
so Mr. Iknoweverythingandimgonnabeadickcauseidntknowyou
- is there a headlight fuse im un-aware of? ( cant find anything searching here, and dnt have an owners manual )
- is the ground connected to the ballast harness necessary?
Old Dec 4, 2008 | 02:54 PM
redlude97's Avatar
Did you check those ones
Old Dec 4, 2008 | 02:56 PM
redlude97's Avatar
The ground isn't necessary either, if you are talking about the one hooked up to the ignitor
Old Dec 4, 2008 | 03:01 PM
well if your talking about the ones you can see when u lift that cover then yes,.....are there more than that?.....im at work right now buddy, sorry if im buggin' ya,...im just tryin' to cover every angle, and get some knowledge before i go back and take another look at it today
Old Dec 4, 2008 | 03:03 PM
Hi-TechG35's Avatar
The fuse box they are referencing is ocated behind the battery. You have to remove the battery and the cover. It is a little black box against the firewall.
