Problem: Headlights not working, Fog lights still on
Old Jan 19, 2009 | 12:48 AM
Lucky-G's Avatar
As the title states, I've got a rather strange problem. I have no rewire on my fog lights, still OEM wiring. When the switch is turned to the 3rd positon--headlights and foglights both on--the fog lights turn on like normal, but the headlights do not.
All of the bulbs in the front end were replaced at the same time, roughly 2-3 months ago, and we (me and a friend) were VERY cautious not to touch the lights, using seran-wrap when handling them. The bulbs I used were standard Sylvania's.
1.) No other lights are malfunctioning.
2.) Both headlights stopped working at the same time, so I don't think it's the bulbs.
3.) I can't imagine it being the switch, as the fog lights still turn on like normal.
I did have to jump start my car once, but I can't imagine that being the answer either.
I looked for a fuse and, unless I'm blind, there is no headlight fuse. Is this really the case?
Unfortunately, I have no idea WHEN they went out, as my fog lights are at least 75% of my light output, being Sylvania Ultra's. The hi-beams still work as normal.
Any advice or suggestions?
Old Jan 19, 2009 | 01:11 AM
TroysG's Avatar
did you try the "hidden" fuse box in behind the battery?
Old Jan 19, 2009 | 01:39 AM
Lucky-G's Avatar
Yup, that was actually the first one I checked, lol. Afterwards I figured, "that can't be ALL of the fuses!", then I found the kickpanel fuse box.
Oh, and another thing, I also just replaced the battery, after the headlights started malfunctioning--so it's not a low-voltage issue.
I'm very stumped here. I'm gonna start tagging wires with a multimeter tomorrow and see what I can, or can't, find.
Old Jan 19, 2009 | 02:22 AM
hyperlite21's Avatar
u might have a bad ballast....
Old Jan 19, 2009 | 02:23 AM
at one point in time, i had both of my ballasts go out at the same time....it was weird
Old Jan 19, 2009 | 02:53 AM
Lucky-G's Avatar
Oh yeah, they're not HID's either. Halogens FTL.
Old Jan 23, 2009 | 10:51 AM
Hotrod's Avatar
There should be a relay for the headlights I don't think they would route all of that power through the switch.
Old Jan 24, 2009 | 02:52 AM
Lucky-G's Avatar
*shrug* if there is, I can't find any info on it. By no means saying you're wrong, I just can't effin find the damn thing!
Jusseth
Sep 13, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
bTanz
Oct 15, 2015 02:31 PM
attarday
Jul 15, 2015 04:03 PM
