body shop in/near the SFV questions
Are there any body shops or is there anyone, that could help out with my headlight alignment? not the adjustment screw itself, but the actual headlight itself. it's a little off.. i know it could be a fix such as using a washer on the installment screws. but regardless, is there anyone that might be able to help me out possibly?
also, the adjustment screw on my passenger side projector seems to not be working. don't know if there's a fix for that. I'm turning the adjustments screw, but it's not leveling either up or down.
i need some help, and i'm oh so sad.
let me know anybody.... sommmmmebodddy.
please/thanks
please/thanks
Better to post this in the SoCal section if you want a quicker response. When you turn the screws the light isn't moving up and down? Are you sure you are turning the right screws? is the light going from left to right? If so, you're turning the wrong screw. lol. if not, something might be loose inside your headlight.
BlueBelleG35x
Jul 23, 2015 02:10 PM
