LED Question
Old Jan 30, 2009 | 03:17 PM
keff108's Avatar
LED Question
I just got LEDs in the mail from ijdmtoy.com I put the LEDs to the clear corners and license plates in fine. The only think is What size bulb will fit the clearance strip in my headlights. Since I have the 04 headlights the bulb in there currently is very dull. I want to get a bulb to match the clear corners but I don't know which one to order. Is it the same bulb that's in the clear corners or is it the bulb that goes in the under door light? Or is it a completely different bulb all together? Help would be greatly appreciated. Thanks
Old Jan 30, 2009 | 03:19 PM
dofu's Avatar
20 Year Member
Sylvania Lamp Replacement Guide
Old Jan 30, 2009 | 03:20 PM
Hi-TechG35's Avatar
Should be the same size as the sidemarker.
Old Jan 30, 2009 | 03:23 PM
dofu's Avatar
20 Year Member
The site just went down just now, it should be back up in a bit...
Old Jan 30, 2009 | 03:24 PM
keff108's Avatar
Thanks guys before I even checked back I figured it out. How would I put this bulb in the headlight tho. It seems really complicated.
Old Feb 2, 2009 | 11:58 PM
Ogz007's Avatar
if im not wrong youre talking about the long strip on the headlights right?
(im always confused to what it is called).
anyway, im pretty sure that you have to take your front wheels off then un-screw 3 to 4 bolts on the guard just wher your headlights is. then you can access it fully. this is with the coupes by the way, so im pretty sure it would be the same with the sedans.
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
