HELP! Quick Easy Question! Where is Ignition WIRE?
I'm such a noob when it comes to electronics, so I'm a bit overwhelmed, but I'm installing Halos into my headlights and need to tap into the Ignition Wire (Black & Red) so that I have a constant 12V power source and the ignition will also act as a relay.
Can anyone show me the ideal spot to splice/tap into the ignition wire and where it is specifically?
Also, is it ok to connect power from (2) different inverters to the single spliced connection to the ignition? Basically it will be a Y joint into the ignition with an in-line fuse.
Thanks! Pictures if possible would be appreciated...I've searched and searched and have had no luck and I'm about to take my headlights out.
