need help please
Old Feb 17, 2009 | 02:43 PM
jefroV35's Avatar
need help please
Whats up everyone. I need help installing this led lights. how do i install them? do i have to take the bumper off or can i get it through the wheel well? Thanks in advance
Old Feb 17, 2009 | 03:21 PM
TroysG's Avatar
bumper has to come off, I believe there's a DIY. look up headlight DIYs, as well as bumper DIY. I know I used one when swapping my 04 headlights for an 06
Old Feb 17, 2009 | 03:38 PM
jefroV35's Avatar
hmm thanks for the advice, but i hope i do not have to take out the bumper.
Old Feb 17, 2009 | 03:40 PM
suicidesam's Avatar
****defected****
you go through the wheel well
Old Feb 17, 2009 | 03:50 PM
jefroV35's Avatar
Really?
Old Feb 17, 2009 | 03:56 PM
suicidesam's Avatar
****defected****
Originally Posted by jefroV35
Really?
you ever change your fog lights? if so it's the same way you feel around for the plug in the upper corner. just remember to wrap some black tape around the led securing it to the harness...
Old Feb 17, 2009 | 04:05 PM
jefroV35's Avatar
Thanks i will give it a shot tonight.
Old Feb 17, 2009 | 05:02 PM
BostonG6spd's Avatar
yeah this is fairly easy, just turn the wheel to the opposit side that you are working on, take of the 2 screw, and 4 tabs i beleive, peel the frnder plasic back, and you will be able to see the little harness in the upper corner closest to you. Turn it counter clockwise to take out, and then do it back in reverse
Old Feb 17, 2009 | 05:20 PM
jefroV35's Avatar
Thanks for the advice! hopefully it is as easy as it sounds lol!
Old Feb 17, 2009 | 06:18 PM
jefroV35's Avatar
do you know how much time this will take?
Old Feb 17, 2009 | 07:08 PM
if its ur first time about 15-20 min per side. if uve done it before should take about 8 min per side
Old Feb 17, 2009 | 07:21 PM
jefroV35's Avatar
Sounds good. It pretty cold out so I'll be sure to do it in the garage!
Old Feb 17, 2009 | 09:05 PM
yeah just make sure you have enough light, and a flashlight may help. if you have trouble, some people jack up that side to get more room.
Old Feb 18, 2009 | 04:05 PM
suicidesam's Avatar
****defected****
yo jefro did you change them?
Old Feb 18, 2009 | 04:58 PM
jefroV35's Avatar
yes and they look great! I will post some pictures tonight or tomorrow. Thanks for all your guys help!
