The best way to remove oem sideskirts?
Anyone know the best way to remove oem sideskirts without breaking the clips that attach on the sills? There's hardly any info on removal. Or should I just say "screw it" and rip them off.
Guest
Posts: n/a
If you've taken out all the screws and clips that you can, then you just need to firmly pull. I can't remember, but I think pushing them forward, or back helps (mine slid in one direction about 1/2'').
Still managed to break 1 clip on one side, and 2 on the other and I was overly careful...
lol...now, gotta learn how to weld plastic!!
would this be the same with an aftermarket sideskirts? do you remove it the same way? i would like to remove my ings+1 skirts. not sure which direction to pull, and i dont think there are any clips, i just see screws...
