Taking apart clear corners
Old May 24, 2009 | 07:40 PM
imaxorz's Avatar
I would like to take apart my clear corners for painting purposes.
What is the best way to take them apart?
I searched and found someone that used a circular saw to cut the back off.
Is there an easier way?
Thank you in advance.
Old May 24, 2009 | 09:27 PM
DrewTheSuit's Avatar
you can see the seam on them if you look closely...one side i was able to get a flathead in there and pry apart, the other side required me to dust off the dremel....if you cut them open, you really only need a small spot along the seam and then get a small screwdriver and run it along the rest of the seam
Old May 25, 2009 | 12:09 AM
imaxorz's Avatar
^ thanks a lot. I'll mess with them tomorrow.
Old May 27, 2009 | 10:01 PM
imaxorz's Avatar
I did it over the weekend!
I started in a corner with a dremel then carefully pried them open with a screw driver.
Thanks a lot!
Old May 28, 2009 | 12:14 AM
no problem
mbe093
Lights
Oct 2, 2016 11:09 PM
redonblack35
Accessories
19
Feb 13, 2016 11:19 AM
RA081024
Aug 18, 2015 07:03 AM
underworld
Aug 6, 2015 01:36 PM
