Need Help With LED Project
Old Jun 17, 2009 | 12:16 AM
Dishank08's Avatar
Hey,
I was planning on doing some LED work. I have a 2006 G35 Coupe.
I want to change the following:
- License Plate Light
- Back Up Light
- Map Light
- Vanity Visor Light
- Step/Courtesy Light
- Trunk/Cargo Light
What bulb sizes would I need for each of these?
How do I change the Step/Courtesy Light?
How do I change the Vanity Visor Light?
Old Jun 17, 2009 | 12:18 AM
0MGHI2U's Avatar
there is a DYI on this.. and a SEARCH BUTTON.. but since i know how to do it i just explain to u..
here is the list of bulb sizes:
Parking light
168
168LL Long Life Upgrade: Up to twice the life of the standard lamp
Front turn signal
7440
7440ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
7440LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear turn signal
7440
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
H1
H1ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
H1XV XtraVision Halogen - The Brighter Light
License plate
168
Back up light
921
921ST Silverstar Signal Lighting: Complete the Look: Crisp, Clean, Style
921LL Long Life Upgrade: Up to twice the life of the standard lamp
Front sidemarker
194
194LL Long Life Upgrade: Up to twice the life of the standard lamp
Rear sidemarker
194
Map light
DE3175
DE3175LL Long Life Upgrade: Up to twice the life of the standard lamp
7443LL Long Life Upgrade: Up to twice the life of the standard lamp
Dome light
DE3175
Step/Courtesy light
DE3022
Trunk/Cargo area
158
Old Jun 17, 2009 | 12:20 AM
0MGHI2U's Avatar
i have all leds in my car for www.v-leds.com.. great stuff.
1.to change the step courtesy lights you look under your door where the light is.. and you get a flat head and you should see a flat spot.. just pop it out... and pull down so you change the bulb..
2.to change the vanity visor light you open the visor lid. i used a credit card stuck it in the light housing (plastic cover) underneath it and slowly start popping it out..
BAM!!!! DONE!!!
Old Jun 20, 2009 | 09:16 AM
BuckeyeInMI's Avatar
OP, definitely do some searching here for LED upgrades. The trunk, side markers, and license plates all use the same type of bulb. 158=168=194. Also, the door/courtesy and map lights are the same style, DE3175=DE3022. You can put some of the 3x3 bulbs in either location, and I think you can put 4x4's in the map lights.
I just ordered some 194 bulbs from v-leds.com that were on sale, 25% off some of them.
Old Jul 14, 2009 | 11:20 PM
Aquarius's Avatar
i hate that damn step/courtesy light.. for the life of me, i cant pull it out because first its too hot to touch, still plugged in so i cant pull it out too far out the crack, and then if i find a way to get it out, i dont even know how to make the 12 smd LED fit but i'll get to that when the time comes
Marlin84
Apr 1, 2020 12:52 PM
g.spot
May 9, 2016 10:54 PM
Gabe83714
Oct 6, 2015 06:40 AM
Albanian122
NorthEast
Sep 28, 2015 03:03 PM
doakley92
Sep 25, 2015 12:58 PM
