M35/45 Door Handle Mod for G35 and G37!
Old Aug 5, 2009 | 05:27 PM
Ray@OCInfiniti's Avatar
Just wanted to toss this out there for anyone looking for a bit more "bling" for their G.
You can upgrade your door handles to the M35/45 handles on your front and rear doors!
The M35/45 uses the chrome trimmed handle and escutcheon (keyhole cover / delete) where the G is fully painted. Both M and G have the handle button as well.
Add a bit more style and set yourself apart from the crowd but upgrading to these handle assemblies.
For some time now, we've known that the door handles for the newer Y50 body style M35/45 and the newer G35 4d, G37 4dr and G37 2dr were basically all the same design only exterior differences.
As you can see from the pics below both share the same exact layout and design, so fitment is not an issue. Where the handles bolt to the car itself, the fittings are identical, and on the backside, they are recessed in exactly the same spaces for clearance.
the one and only difference between the two is the wiring plug on the back of the handle. Each handle has two seperate plugs, one plug is identical to each but there is a second plug that on the M will be differently sized/shaped and you will need to cut and splice these two to your existing harness on the G. Not a hard task at all to do.
here is a pic of the differences:
These handles are currently available in the following color codes only:
QAA KH3 K23 K51 K52 B30 HAA KAC
We will be looking into other color codes as well soon.
Chrome keyhole covers are not included and are seperate, but available, including the ever popular keyhole deletes.
PM us for pricing and questions!
Tony@riversideinfiniti
Rick@riversideinfiniti
800-919-8130
Old Aug 10, 2009 | 07:54 PM
visibiliti's Avatar
bump for clarification- this does not apply to G35 coupes?
Old Aug 11, 2009 | 03:03 AM
Wrathernaut's Avatar
Gentle Manne of Leisure
I love the '07 sedan handles. Now I wish I had them even more.
Old Aug 11, 2009 | 11:42 AM
bina12834's Avatar
they shoud fit just the same
Old Aug 11, 2009 | 11:58 AM
The Stimulation's Avatar
No QX1
Old Aug 11, 2009 | 12:58 PM
WhosUrBuddiee's Avatar
Old Aug 12, 2009 | 01:59 PM
we have not tried matching these up with a G35 coupe yet.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
sick_sixspeed
Jul 21, 2015 01:59 PM
