Lower door molding
what happened? did yours fall off? i have a coupe and mine started coming out... inside the rubber there is bendable metal so i just squeezed it and stuck it back onto the lip and havent had any problems since!
Call Robbie at Pearson Infiniti hes the parts manager 1-800-285-0300. Its call the weather seal or something like that. Pretty sure its like $79 color matched and everything. Hes located in Richmond VA. Also if you look at the bottom of the door you can take it off its just like 7-8 quick snap black peices that pull right off.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
