Undercarriage
Undercarriage
Ok, to try and make a long story short... I'm looking for a new undercarriage for my car. For both the right and left wheel wells along with the long plastic part beneath motor that connects the both inner wheel wells. Theyre usually all attached, but in some instance ive seen the inner wheel wells sold but not the piece inbetween. Any ideas where i can find the whole thing?
Appearantly when the shop installed my Kuruma Z, they didnt put all the clips back in place for the undercarriage. So as you can imagine, on the highway, it drops and my tires melt this poor thing away. I had to take the whole thing off because it was badly damaged, but now i need another in fear of water kicking up and doing the unimaginable. I have no clue where to find tho. Any inputs?
I'm experiencing the same issue. After I changed the oil, I did not bolted my undercarriage cover tight enough so mine is all messed up. Bolt holes on the bumper are ripped and I am not sure how to fix it at this point....
mine are all zipped tied up as well....
I didn't clip up the center part under front bumper i guess. Was trying to get some speed on the stretch home and it dropped down making a horrible dragging sound. It half ripped underneath making it impossible to clip back on right. Had to cut it ghetto style. Then long story short another thing lead to me having to remove the driver side wheel well plastic cause a xenon headlight to short out cause it rained......
Elegant solution: http://my350z.com/forum/body-exterio...are-ready.html
And yes, they fit G35 Coupe and Sedan with OEM bumper.
