one of my 3rd brake lights is out
Does anyone know what type of bulb these are? My dealer (good quality, but **** poor customer service! Geez!) said the bulbs are on order. I don't want to wait around for them to order me a light bulb when I am sure I can just change it myself. Thx for any help!
-drew
standard disclaimer: yes, I tried the search function. yes, I am an idiot. yes your car is faster than mine.
-drew
Re: one of my 3rd brake lights is out
Does your car have the factory spoiler? Or does it have the third brake light assembly in the rear window.....
First, I would check in the owners manual under routine maintenance/specifications, it should tell you which bulbs or LED's are used......
I think they use LED's in the third brake light, I'm not sure about the spoiler, but its probably the same......Might be something the dealer should take care of for you...........
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Oh. . .no spoiler on my car. Light is in the rear window. It's the third element (bulb?) that is burned out. The dealer will take care of it, but recently I've had to take my car in way too often for little things like this (plastic here, bulb there. . .) and I wanted to try and avoid the hassle. But if I have to, I have to. . . .
-Drew
-Drew
FS[SoEast]: 2006 DG Coupe Part Out - mrev2, projectors, etc
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
