Front Grill Removal- How?
Old Oct 25, 2002 | 02:28 PM
Gordgee's Avatar
Administrator
Does anyone know how to remove the front grill? After removing the six clips from the top of the grill and bumper facia, I can't figure out how to remove the turn fasteners that hold the grill to the bumper facia.
Thanks in advance.
Old Oct 25, 2002 | 09:46 PM
Gordgee's Avatar
Administrator
Re: Front Grill Removal- How?
glw;
Thanks. The two square screws are what I was calling turn fasteners. What do you use to turn them?
Old Oct 25, 2002 | 11:39 PM
Gordgee's Avatar
Administrator
Thanks again. I never noticed the thin slot before. I'll try a screw driver on it tomorrow.
BTW, That sensor behind the grill is the 'Ambient Sensor' that reads the outside temperatures on your Climate Control display.
Old Feb 9, 2003 | 03:29 PM
crea's Avatar
i found those 2 flat square thing
but it's impossible to turn!!
Old Feb 9, 2003 | 04:09 PM
crea's Avatar
how do u remove the front badge?
Old Feb 9, 2003 | 05:24 PM
Gordgee's Avatar
Administrator
You only need to turn them 1/8 of a turn, then the grill will move forward. I think that you can remove the Infiniti badge once you have the grill off.
Old Feb 9, 2003 | 06:54 PM
crea's Avatar
but the square thing wont even move....
like it move abit, then it goes back to normal....
do i need to align the square tap with the hole?
Old Feb 9, 2003 | 07:08 PM
crea's Avatar
so do i turn clock wise or counter clockwise?
Old Feb 9, 2003 | 08:03 PM
Gordgee's Avatar
Administrator
I think you can turn either way. You just want to match up the shape of the square to line up with the square hole.
Old Feb 9, 2003 | 08:25 PM
Gordgee's Avatar
Administrator
BTW, make sure that the garage or where ever you're working is fairly warm. What you're doing is twisting the shaft of that black plastic stud. In cold temperatures, it might snap off! [img]/w3timages/icons/frown.gif[/img]
Old Feb 9, 2003 | 11:17 PM
rjt4re's Avatar
I have a coupe and all you need do is reach in back of the grille and squeeze the two plastic tabs inward and the badge pops right out.
Old Feb 14, 2003 | 08:19 PM
Gabe35Coupe's Avatar
If you are talking about the coupe, after removing the fasteners on top, there is a tab on each side of the upper portion of the grill that expands after it is pushed through the facia. The part that expands faces up and down, not side to side. If you squeeze it togother with some needle nose pliers and pull out it will come away from the facia. There are locking tabs on the bottom as well but are pretty easy to remove. I did it while the facia was of, which might have made it easier.
'03 G35 Coupe 6spd, brilliant silver, graphite leather, premium, aero and nav packages.
jsimonk
Dec 22, 2023 03:49 PM
Th611
Oct 27, 2015 03:48 PM
rsingerG35
Aug 18, 2015 10:16 AM
linedr89
Aug 17, 2015 05:11 PM
realtalk21
Jul 20, 2015 09:07 AM
