LED Lighting - Interior & Exterior
Old Jan 25, 2010 | 10:42 PM
1LuxRide's Avatar
Lightbulb LED Lighting - Interior & Exterior
Hi guys,
I tried doing some research about the LED lighting for our G's but still there is to much out there scattered all over the place. So I figured I start this thread to get some good ideas all in one place. I guess I can start off by asking you pros which type of LED's you recommend for my 2003 G35 SEDAN - I know I want to go with plain WHITE so let's stick to that. I just need to know the sizes and types of brands that really make the light stand out. Does not have to be the most expensive stuff out there you know, just something that will look nice and white.
I need the following:
Interior front dome lights (2)
Interior rear top of window lights (2)
Front two door bottom lights (2)
Reverse lights (2)
Rear license plate light (I think only 1 for my year)
The two small lights within my headlights (2)
Two interior mirror lights (2)
Trunk light (1)
I need also my clock light, both burnt out so its dark (2 I think)
Glove compartment light (1)
I think that's it but if I am missing something please let me know.
Thanks guys, with your help my switch should go smoother.
Old Jan 25, 2010 | 10:46 PM
CandlestickPark's Avatar
ill Sedan
Not sure if you came across this thread already, but lots of good info in here:
https://g35driver.com/forums/lightin...k-pc-hang.html
Old Jan 25, 2010 | 10:49 PM
mconklin's Avatar
there is a sticky with all the replacement lights w/ the codes in this section...v-leds is the most common brand and you can get them from amazon cheap as well.
Old Jan 25, 2010 | 11:08 PM
1LuxRide's Avatar
good tips, thanks guys...i will look into those
Old Jan 25, 2010 | 11:17 PM
Calvin's Avatar
Overglorified Altima
mrwong@statik - PM him. these are the best LEDs ive ever used...and ive gone through plenty.
Calvin's Avatar
https://g35driver.com/forums/accesso...plate-led.html
derres
Aug 28, 2015 03:27 PM
RA081024
Aug 18, 2015 07:03 AM
linedr89
Aug 17, 2015 05:11 PM
EPG35
Aug 16, 2015 04:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
