07 g coupe OEM grill removal
Old Jun 15, 2010 | 03:43 AM
g(thirty-five)'s Avatar
Can someone help me with a detail explanation on how to remove the grill.
I removed all the click above the grill and Im not sure how to remove to clips inside below to grill (dont want to break them) Thank you
Old Jun 15, 2010 | 06:26 AM
dukehotty's Avatar
I had the same problem. You need a thin screwdriver and a slight twist. Think of it like twisting a diamond shape through a square. There is a GREAT DIY here on the forum. That is how I learned!
Old Jun 15, 2010 | 12:15 PM
walshtj's Avatar
yeah search, there is a step by step DIY
Old Jun 15, 2010 | 12:16 PM
GR6RR's Avatar
just pull really hard...
Old Jun 15, 2010 | 10:10 PM
so i got out the two top square clips out and im not too sure about the bottom ones.....ill check out the DIY. Thanks
Old Jun 30, 2010 | 08:30 AM
EnJoiLuv's Avatar
I took mine out just recently. All you need is a (-) screw driver.
1. Pull out the clips at the top of the grill.
2. Remove the clips on the side of the grill thats holding on to the bumper. Just twist the top of the clip with the screw driver and pull and it should come out. (It takes a little twisting around with it to make it come out.)
3. Pull on the top of your grill and push the top of the bottom clips thats holding your grill onto your bumper and viola! You're done!
I did it with mine w/o a DIY and it was pretty simple.
mushu
Jul 15, 2015 03:55 PM
