Tail-light overspray?
Old Jul 11, 2010 | 02:32 PM
digital sol's Avatar
So i have an 04 coupe and finally have a day to clean her up and get some things done
-polished headlights/tail-lights
-debadge
-clean leather etc'
anywho, it looks like maybe the rear bumper had been re-painted at one time because there is over-spray on both tail lights right on the bottom area, about 1/2" up on both sides, its not super thick like it looks like the car but its definately paint overspray, ive clay-bar'd the hell out of it but its still not completely gone
can i use a high grit wet sandpaper to remove the rest of it and then just re-polish the tail light with meguiars headlight restoration kit?
what grit should i use on the tail lights?
thanks fellas, i really appreciate it, ill take pics after she's all cleaned up
Old Jul 13, 2010 | 11:21 PM
pattyballs's Avatar
you can try wetsanding them with a very high grit. I would say try 2000. that should be just enough to get off the overspray. As far as the meguiars headlight restoration you might need a better polish. Any 3M polish should do the trick tho!
Old Jul 19, 2010 | 01:48 AM
Bri127mx's Avatar
you havent tried any chemicals? now sure what acetone or regular gasoline would do to the finish, but they should get the paint off
pj-le
Archived Sales
Apr 22, 2008 07:56 PM
DocJohn
Jun 5, 2007 04:02 PM
G35_TX
Feb 4, 2006 07:47 PM
Daniele
Mar 7, 2003 05:03 AM
