Brake light in back window is out
Old Jul 12, 2010 | 09:16 PM
eddlove2001's Avatar
back window brake light went out, My 03 g35 sedan didn't come with a manual. I also have 2 kicker 12 beating down the block, could I busted LED panel and where should i start?
Old Jul 19, 2010 | 02:59 AM
mrzdude2000's Avatar
Working on mine now. I'm using a 4 double A battery pack to test the lights. By bypassing the middle lights, I can get the outer 4 to come on. I will be looking for replacement leds. Check out this thread for removal. You can go through the trunk without drilling but it will be hard to get both screws back in when you're done.
Old Jul 21, 2010 | 01:39 PM
GR8TG35's Avatar
Had the same problem with my 04 coupe last year. Dealership told me it would cost around $295 to replace the assembly. Told me the whole rear interior of the car has to be removed in order to get at the connection.
I smelled BS big time, so I got in the back of the car and removed it myself by simply pushing the whole assembly towards the rear window, and lifting......low and behold the connection was right there.
I ordered a new brake light thru the Nissan Dealership I was working at at the time....with my discount it cost $100. I thought I would have to replace the led assembly, but for that price I received a complete assembly....simply plug and play.....don't know if this is true for the sedan people.....
Good luck.
Old Jul 22, 2010 | 02:15 AM
Wannabe6MT's Avatar
-MN G Crew-
^Same with us.
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
apintojr
Jul 23, 2015 10:52 AM
Lsantana757
Jul 20, 2015 09:08 AM
Jadenkid22
Jul 14, 2015 12:33 AM
