Anyone know of any body color filler material?
Old Jul 30, 2010 | 04:15 PM
Pollock21's Avatar
Hey guys, I've heard that there exists some type of body color filler type of deal out there. I have an issue where my ings kit mounted to the front of my car. You can see the line left where the 3M tape is sandwiched between the bumper and lip.
I'm looking for some ways to cover that up. As a temp fix, I'm thinking about touching up the tape with some touch up paint. It won't look the best, but it'll help it blend unless you're really close.
Any advice? I know molding is an option, but local shops that do good work and don't charge a fortune are pretty much non existant.
I'm trying to find a decent affordable fix.
Old Jul 30, 2010 | 05:14 PM
biggerandbetter's Avatar
ummm, my best suggestion is to just hold off until you can fix it right.
Old Jul 30, 2010 | 05:23 PM
Pollock21's Avatar
What's the best way to fix it right?
Old Aug 1, 2010 | 06:21 PM
Pollock21's Avatar
Well, I'm going to touch up the tape with paint, just to take the edge off. There's no harm in that. Still looking for advice on the best way to "mold" the lip to the bumper.
Old Aug 2, 2010 | 10:35 AM
G2FLIP4's Avatar
everything
3M or Fusor make body panel adhesives. That would be the right way to mold it. Then run a bead of bodyfiller(not Bondo brand, that stuff is garbage) along the seam and smooth it and respray the bumper.
Ive used Fusor products in the past, it pretty much tears apart urethane parts if you try to pull it apart. Like instead of the Fusor giving, it tears apart whatever you've bonded, its that strong. Works on urethane, ABS, fiberglass, metal... pretty much anything as long as you use a grinder to scuff it up first.
esotericrider
Feb 14, 2022 07:19 AM
carid
Aug 22, 2016 01:34 AM
tiguy99
Mar 1, 2016 11:42 AM
ghost_g35
Aug 7, 2015 10:31 AM
