Lights
Old Oct 14, 2004 | 11:25 PM
SDG35cOwner's Avatar
Lights
I got my car repaired someone hit my front light and i when i turned the lights on tonight the inside lights wouldnt turn on but when they were off the inside lights would be on. Before i call and bitch this place out is there anyway i can fix it?
Old Oct 14, 2004 | 11:51 PM
g4s's Avatar
g4s
Re: Lights
if for whatever reason they had to remove the panel below the steering wheel, check the functionality of the dimmer switch. if the harness for that switch is disconnected, you will experience the issues you are describing.
Old Oct 15, 2004 | 10:58 AM
SFLG35's Avatar
FGC President
Re: Lights
turn the dimmer switch back up. im sure it just got turned down by accident or maybe like what was mentioned above it got left unpluged. hope that helps.
Daniel
screw the GTC's. Maya RT5's now!!!
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
cmesidewayz
Sep 29, 2015 09:28 PM
neight
Interior
Sep 21, 2015 05:35 PM
Jnm07
Sep 5, 2015 01:16 AM
