Rare JDM Aluminum Under Panel Installed REVIEW
Old Nov 18, 2010 | 07:51 AM
  #46
jin22gt's Avatar
There are 3 different companies making the underbody shield? (rarejdm, zspeed, arc)
And the awd sedan(05) underbody shield are different?
Old Nov 18, 2010 | 07:10 PM
  #47
djfarhan's Avatar
anything for the 07 sedan?
Old Nov 18, 2010 | 07:57 PM
  #48
snakes1021's Avatar
i had to cut and bend the metal in my oem one to fit my gtspec front lower tie bar. i wonder if any of the aftermarket undertrays will fit around that bar
Old Nov 19, 2010 | 12:00 AM
  #49
richardcvan's Avatar
looks nice.. it seems like when its dirty it will look nasty!
Old Nov 19, 2010 | 12:10 AM
  #50
JBF's Avatar
JBF
man that's way expensive...
pretty...
but expensive...
I have the Z-Speed one and it has taken a BEATING with as low as I am and there's only one dent in it from hitting a cell phone doing 75 on the freeway (yes a cell phone)
the latest Z-speed has enough adjustment to work with a slew of aftermarket bumpers.
Old Nov 24, 2010 | 03:42 AM
  #51
Jairen's Avatar
Finally got around to doing my first oil change with the undertray. It's gotten pretty nasty with the rain and hasn't been wiped down. So far it looks good with just some water spots.
Good thing I have access to a lift.
IMG_1869.jpg?t=1290587951
Looks like I have a leak somewhere.
IMG_1867.jpg?t=1290587951
German Castrol and PureOne filter FTW! $27.99 at Pep Boys.
IMG_1870.jpg?t=1290588085
Old Nov 24, 2010 | 11:14 AM
  #52
djfarhan's Avatar
Question
Old Jan 3, 2011 | 02:25 PM
  #53
CandlestickPark's Avatar
ill Sedan
Finally got around to installing my RareJDM Polished Aluminum Underpanel this past weekend. Install was very straightforward, everything fit just like OEM.
I am very impressed with how strong the underpanel is. We punched it pretty hard once it was installed on the car and it didn't budge at all. I'm also very pleased with the fitment on the car. It sits very tight up against the car, higher than my OEM undertray did. Since I'm slammed my OEM undertray took a beating everytime I drove my car and was constantly on the verge of falling off. I haven't even scraped the RareJDM underpanel yet because its sitting up higher.
I opted to install mine with the front of the underpanel above the front bumper vs under, so that when I scrape it wont get caught on anything. I had my OEM undertray installed the same way.
I didn't get any installed pics because it was dark, will get some pics on the car soon.
Overall I'm very impressed with the quality, fitment and strength of the RareJDM underpanel. I'll post up my experience with the underpanel after driving around and inevitably scraping it. I'll let you know how it holds up.
Old Jan 3, 2011 | 02:28 PM
  #54
g35man04's Avatar
CLUB MODERATOR
very nice Marcus! I need to get mine ordered soon!!! my tollboothwilly may not last much longer...sadly when I installed the GT Spec Front tie brace it didnt fit..I modified everything by adding in some nylon spacers with longer bolts to count for the distance needed to install the brace.
Old Jan 3, 2011 | 02:34 PM
  #55
ill Sedan
Thanks Chris. Your GT Spec front tie brace was hitting your undertray? I installed the rear brace but didn't have time to do the front that day, will do it soon. From what I've seen there shouldn't be an issue with the underpanel and the front tie brace.
Didn't you used to have an ARC underpanel too...
Old Jan 3, 2011 | 02:42 PM
  #56
g35man04's Avatar
CLUB MODERATOR
Thanks Chris. Your GT Spec front tie brace was hitting your undertray? I installed the rear brace but didn't have time to do the front that day, will do it soon. From what I've seen there should be an issue with the underpanel and the front tie brace.
I believe I installed it right according to directions but yes it was hitting my Aluminum Tray and wasnt even close to mounting up...
my front brace is installed here...im fairly certain that is the correct way..and yes it does sit lower than my Motordyne Sway bars by alittle under 1/2 inch.
Old Jan 3, 2011 | 04:22 PM
  #57
ill Sedan
Here is another installed pic of the GTSPEC front tie brace, I believe you have it installed correctly.
I'll try and get mine on soon and I'll report back on the fitment.
Old Jan 3, 2011 | 04:24 PM
  #58
g35man04's Avatar
CLUB MODERATOR
yeah because my motodryne sways I believe rub just a tad on the shield as well...do you have aftermarket sways?? I would Zack at rarejdm would design your to clear aftermarket bars...
Old Jan 3, 2011 | 04:30 PM
  #59
ill Sedan
Yes I have aftermarket sways (Stillen), no rubbing issues against the underpanel at all.
Old Jan 3, 2011 | 04:31 PM
  #60
g35man04's Avatar
CLUB MODERATOR
okay. I wonder if its the aluminum underpanel I have..I know the ARC panel I had was plenty for clearance. not sure on the front tie brace since I never had it installed before until now.
