Front bumper questions
I have seen two different bumpers on 03-04 Sedans and I am wondering what the difference is and how I would order one:
https://g35driver.com/forums/attachm...00_2771-1-.jpg -- This is the style I currently have http://inlinethumb28.webshots.com/46...600x600Q85.jpg -- This is the one im looking to get |
The first one is the standard bumper.
The 2nd one is a factory body kit often called the "Nismo Areo" kit. Unfortunately, Nissan no longer makes the Nismo bumper :( Your only options now are fiberglass replicas. One is made by Vis and looks very similar to the OEM bumper The other is made by HikkataDori, and is a revised version of the Nismo with the license plate area smoothed out (that's the one I have) |
^ Doesn't the one from VIS only fit 05-06?
Also (OP), if you do some searching around the marketplace (on this forum), Ebay and other internet sites, you might luck up on a used or refurbished Nismo Aero Bumper. Depends on if you want fiberglass (HikkataDori) or Polyurethane (factory Nismo). Think there are a few on Ebay right now. But, hope you got deep pockets, cause they aren't giving them away! GL! rob.g |
All,
Thanks for the info! |
The Vis only fits 03/04. HikkataDori has fitment for either, though you need to specify if you have the 03/04 or 05/06.
Doesn't really matter for the OP though as he has an 04. The OEM, Vis or HD will all fit. |
