Driver Window Problem!
Old Jan 2, 2011 | 06:07 PM
extremepowderco's Avatar
Ok i been looking all over the forum for my answer and cant find it! I had to take my window motor apart an clean it so my window will work again! Ok window is working good again! Here's the issue im having. My window goes down and stops just fine. When i put the window up it goes all the way up then down 3-4 inches an stops. Its not stopping at the normal 1/4-1/2 inch for factory window door open drop with the door open. What do I need to do?
Thanks for anyones help!
Old Jan 2, 2011 | 07:06 PM
Unleaded91's Avatar
Try resetting the window motor. IIRC there is a button hidden once you remove the door panel that resets the window motor. Give it a try. It might fix it.
Watch this video. Somewhere in the middle they show how to reset the window motor.
http://infinitihelp.com/diy/gcoupe/p..._procedure.htm
Old Jan 2, 2011 | 07:12 PM
Thanks Ill try that!
Old Jan 2, 2011 | 07:19 PM
That worked thanks for the help!!!!!
Old Apr 6, 2011 | 10:16 PM
cupldayzb487's Avatar
@ 14 minutes... For those that don't want to waste their time watching the whole video, like I did!!!
mike730
Jan 12, 2018 04:25 PM
will091195
Jul 27, 2015 09:19 PM
Kal Hamm
Jul 24, 2015 08:55 AM
apintojr
Jul 23, 2015 10:52 AM
attarday
Jul 15, 2015 04:03 PM
