Inven Front Owners
Old Jan 20, 2011 | 06:47 PM
dcityjatt's Avatar
Exclamation Inven Front Owners
Hi guys,
For those of you have the Inven front, did you or your shop run into any problems trying to fit the factory undertray with this front bumper? How did you solve this problem? I would like to retain the undertray, if possible. What suggestions you got in order to make it work. Is zip-tie my only option? Please advise!
Old Jan 21, 2011 | 02:13 PM
JZ's Avatar
JZ
G35 Coupe KY0
zip ties are pretty much the only option. I remember when I was fitting the inven and the undertray together I drilled the holes and screwed them in somehow but I may have lost some parts, I gave up and zip tied them.
Old Jan 21, 2011 | 02:37 PM
nismoz's Avatar
^what you mean by you have lost some parts? Undertray is like a plastic sheet and just screw it under the bumper. There is no other parts besides the undertray and some screws.
Old Jan 21, 2011 | 02:40 PM
psycobusa's Avatar
short self tapping screws is all you need...if your shop can't figure that out, i don't think i'd have them working on my car.
Old Jan 21, 2011 | 03:59 PM
dcityjatt's Avatar
psyco-can yu elaborate a bit more, i am not familiar with what they are, and how they can be used?
also because of the inven front bumper, did you have any issues with the fender liners on the passenger and driver sides?
Old Jan 22, 2011 | 12:49 AM
psycobusa's Avatar
mine look like the short black screw (2nd item on the page) but mine might be a little longer.....you can get them at any hardware store ACE, Home Depot, etc....i have the self tapping screws on connecting the fender liners to the cover and some beefier screws like the oem ones holding the undertray to the cover. it can be attached a million different ways.
http://www.sears.com/shc/s/search_10...rews&seaxbla=1
Old Jan 25, 2011 | 12:59 PM
JZ's Avatar
JZ
G35 Coupe KY0
before we painted my inven I lined up the under tray and drilled the holes myself. (to avoid further $) once i got it back I lined up the bumper and the undertray and it wasnt the same as when I drilled them. I just gave up and went with zip ties.
Old Jan 25, 2011 | 06:35 PM
dcityjatt's Avatar
is anyone with the inven running the undercarraige provided by Tollboothwilley?
Old Feb 4, 2011 | 02:50 PM
rcdash's Avatar
Guys, there is an opportunity to get in on a group buy for the INVEN in poly (click link in my SIG)! This will be designed to match up to the OEM undertray. All you fiberglass owners, when you're slammed like patman530 here, that's even more reason to invest in poly!
The group buy is going but from another vendor. This will be 100% compatible with the undertray! Here is the link:
https://g35driver.com/forums/interio...ndustries.html
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
DimQ
Aug 14, 2015 02:04 AM
Team STILLEN
Aug 10, 2015 08:17 PM
