steering wheel controls
Old Feb 14, 2011 | 12:37 AM
liljohnny's Avatar
Originally Posted by Enigmatic42
there are plenty of cars out there with blue gauges, im sure if done correctly it's just as fine as amber honestly. the color itself wont hurt your eyes, its the brightness and angle of the LEDs
Oh I know there is and I much prefer the amber. Blue looks ricey to me and your eyes are more sensitive to blue light under low light conditions which in my experience, causes eye fatigue after long periods......
Old Feb 14, 2011 | 11:43 AM
jwin100's Avatar
in my opinion, blue is classy, amber is old. go ahead and sit in a new g and tell me that you dont love the color.
Old Feb 14, 2011 | 02:08 PM
TannerG's Avatar
I remember a DIY for this with pictures and everything. It was pretty detailed.
*edit I don't think this is exactly what you are trying to do, but it should help: https://g35driver.com/forums/body-in...-04-coupe.html
Old Feb 14, 2011 | 02:27 PM
g35man04's Avatar
CLUB MODERATOR
what you posted Tanner is the exact process to remove the steering wheel, steering wheel controls for all year coupes. I even believe the same for sedans. he should be able to use that without a problem...OP it takes all of 30 mins to remove the steering wheel and airbag. 2 TORX screws on side of wheels....pop off the black/willow caps witha flat head. take of the 2 bolts...airbag should come lose. Pop off the 2 connections in the back of the airbag. should be yellow and orange. read the DIY on the correct way to do it.
Last but not least undo the TORX Bolts on the steering wheel after the airbag is remove with the steering wheel still bolted on so that you dont have to try and break them lose with the steering wheel already off the car.
after broken lose then you can remove the center nut holding on the steering wheel..GIVE ALITTLE wiggle and it should pop right off.
Old Feb 14, 2011 | 04:20 PM
liljohnny's Avatar
Can't argue that but it hurts my old eyes
Old Feb 14, 2011 | 11:06 PM
jwin100's Avatar
Thank a lot you guys. Very detailed With the instructions. I'll be doing it as soon as possible. I was supposed to get my lights in to do the gauge cluster today but they haven't showed up. Hopefully this week sometime. I'll try to remember to post up some pics and maybe some DIY for ya.
Old Feb 15, 2011 | 01:13 AM
g35man04's Avatar
CLUB MODERATOR
got mine installed today...need to adjust the accel/resume switch..
gauge cluster isnt done yet because im waiting for my nismo cluster to get finished up. will also finalize the AC display once we can determine how to convert an 03-04 AC Display to blue since there are no light and no LEDS
Old Feb 15, 2011 | 05:17 PM
Enigmatic42's Avatar
so the 03 coupe doesn't normally have light up buttons on the wheel? it's not possible to simply replace them you have to actually wire in the lights? k nevermind...
jsimonk
Dec 22, 2023 03:49 PM
derres
Aug 28, 2015 03:27 PM
Gip
Aug 24, 2015 05:31 PM
kd03g99
Jul 30, 2015 11:24 AM
